- Joined
- May 4, 2018
- Messages
- 483
- Reaction score
- 781
- Location
- Ocean County, New Jersey
Blazing Blue Pearl
Real nice on these north east trailsAhhhh that’s sick haha never thought of that
IKamper live up to the hype?Went camping for the 4th.
Just added a custom drive shaft from Tom Wood Custom Driveshafts. Since I lifted my taco I had bad vibrations. Since I put the new one on it’s so smooth! Plus it’s DOM metal so it’s stronger than the factory one. And it’s not a two piece shaft! Worth the money!
there are three videos in three separate posts, each about 30 seconds, that chronicle the whole thing.Where’s the ending!!!
noob question again :
I got 5 full size wheels and tires going on the truck. Do I run 5 TPMS sensors? Factory says you can only really ever run 4... but how do I rotate in my spare tire? Or do you just rotate in your spare with no tpms?
My spare is just rubber stem. I do not get a TPM light truck still reads all 4 tpms even if its not mounted. The spare on the swing out still gets read if it has the sensor on it . I rotate the spare every time when i do the rotating.noob question again :
I have the same question about the TPMS sensors....Im about to put on new tires, and would like to know if I need to buy another TPMS sensor for the spare.
How high did you go? and is the retention cup upgrade in the front axle not a thing anymore? Or was that just the previous generation tacos?
I ask as I've definitely not planned for a driveshaft swap with my icon suspension.
The computer is only capable of monitoring 4 tpms sensors. You just have to rotate one tire in without a sensor. Sometimes it'll throw the system off, but whatever. I just deal with it. I certainly don't dismount two tires and remount the one I rotate in by swapping the tpms.
Thanks for confirming my suspicion. Much appreciated
I only rotate 4 and if I use the spare it's always temporary. If you are planning on putting your spare into rotation then it's worthy of having a TPMS sensor. NBD if you have to reprogram them every time after rotating, takes two seconds and to me it's worth it to have all 4 corners monitored.
Should I order a factory tpms or just grab one online? got a link? I see tons of these but worry about quality and functionality.
Finally mounted my winch. It’s only been sitting in my garage for 3 months
That happens. Although in your defense you have been busy on another project.
