drizzoh
Hell yea! Now you can buy a Gen 4, find another forum, and start all over again!. HAHA!
What's emmisions testing?Passed AZ emissions yesterday with KDMax and all 22k of my miles.
Only place in the State that does emmisions testing, is St. Louis. I'm not sure if because Illinois or what. St. Louis is awful, I much prefer Kansas City.I'm just happy I only have one car that needs it since the Supra is exempt.
Yeah.. Most of AZ doesn't have it but they do in Phoenix metro, so I get to. Not a big deal since I don't plan on putting headers on the Taco and anything else I buy will be old unless I decide to do a VIP (which won't get many performance mods).Only place in the State that does emmisions testing, is St. Louis. I'm not sure if because Illinois or what. St. Louis is awful, I much prefer Kansas City.
NICE!! I assume those are just a replacement style for the OEM with no lift correct?Installed new shocks and struts today. The OEM Bilsteins still felt pretty good for 103K but there were certain situations where they felt kinda weak. They all still had rebound when I took them off but the new KYB Gas a just are about 3 times stiffer to compress by hand, I reused the OE front springs for the struts and it was a really nice improvement. Nosedive when braking is almost completely gone, handling around a corner feels better, I don't feel every single micro bump in the road anymore I barely feel those at all and it doesn't bottom out on speed bumps anymore either. I did the whole job front and rear and front tires back on in 2 hours.
I will keep that in mind for the future. Glad they made a aluminum replacement. I've also heard it's a nightmare to do. Here's to hoping I won't need to do it.Ordered the TEQ coolant bypass pipe today to keep on the shelf until I need it. It's a super common problem on the 3.5l trucks and a super-er unfun install but nice to have a proper cast piece available finally to replace the stock plastic part that is prone to cracking.
2016-2023 Toyota Tacoma 2GR Aluminum Coolant Bypass Pipe by TEQSPORT
www.teqsport.com
Same, and this is much more cost effective and better designed than modifying a Lexus one.I will keep that in mind for the future. Glad they made a aluminum replacement. I've also heard it's a nightmare to do. Here's to hoping I won't need to do it.
Below is not my photo and pretty much the only way to see it is with a boroscope since it's so hard to access, but the factory plastic pipe cracks at its seam and coolant leaks out thru it. It really should be a recall/tsb with an updated part, but the Toyota fix is to replace it with the same flawed part. The Lexus's that use the 2gr motor have a metal bypass pipe, but it is $250, has gaskets instead of o-rings and requires cutting and welding to fit on the taco's. The TEQSPORT is a much better design.Drizzoh, for those of us unfamiliar with this (me), can you walk us through the issue?
Thanks!
My buddy recommended to look at Sams Club. He uses his all the time to charge his kids toys.I have a NOCO. I’ve never used it in my truck, but have to jump others. Works good, just don’t forget to periodically check to charge it. It seems to hold a charge, but sure would suck if it was dead when you needed it!
I took my `21 TRD 4x4 Sport to an aftermarket shop and had them change out the factory Hitachi shocks and install a set of Bilstein 5100`s. It is a very noticeable difference in the ride. Much smoother. I also had my front windows tinted.
Which notch did you go with? Looks similar to mine.Here ya go. She`s still a stock truck with non noticeable improvements. Eventually there will be new tires and a slight lift to it. I`ll post pics of my wife`s Tacoma. Thats the look I`m going for as well.
