Got my Genuine Toyota 17" TRD Gloss Gunmetal Gray (TRD PRO 4Runner) PTR20-35110-G4 wheels with Nitto Terra Grappler G3 tires mounted and installed today. I am exceedingly happy with the result! Love the look and these new Nitto G3's are great tires! So glad I was patient and waited for these, very happy indeed! Something different for my 2022 Limited Nightshade Edition Tacoma.
Looking good.
Added matte black custom "NightShade" bedside decals recently, thought it might be a unique look, I like it, also added American flag decals under the side view mirrors in matte black as well.
More lights? Why not!
Moved GMRC attenna to roof, added Meso puddle pods with switch, added rear chase lights with switch and attempted to rig up a high blinker system but using a four plug and going into the trailer hitch didn't work so I'm going to get some posi-taps and go right to the lines.
111,000 miles first Transmission, Differential and Transfer case oil change. Does anyone know what brand oil base silver paint Toyota uses in those?
I love having a truck! Yesterday I made two trips to bring home 2,000 pounds of bulk compost. So, much cheaper than having to buy the bagged. stuff. Truck beds rock
yanked a couple 60ft trees down. i've got a hedgerow full of dead ash trees. i've cut down all of the ones i could just drop, but had about a dozen leaning the wrong way that would fall on either my shed, garage, or chicken coop. i rope them as high as i can, notch, then cut and leave about a 2 inch web, hook it to the truck, pull slowly till i hear it cracking then jam the gas. the second one i did today had about a 20 degree lean the wrong way but it came down right where i wanted it. fun fun!
Not sure I’m in the right place…here goes
Re: 2015 Tacoma; can l replace JUST the outer red, plastic cover on tail light OTT do l have to replace the whole taillight unit?
Welcome to the forum.
I do not believe you can replace only the outer red plastic cover. I believe the plastic cover is ultrasonically welded to the taillight assembly. However, it has been a while from when I last had my taillight off. I do not think anyone sales anything but the entire taillight assembly. However, you might get more info posting in the modification thread or the technical thread.
I hope that helps.
410 miles until empty? Dang, Mine never goes above 356 and the first 30 miles the DTE number never goes down. Weird. Maybe I'll get better MPG when I get closer to 100k.
I had just filled up. It  says 410 but i havent gotten that from a fill-up in years.
Not today but the other day I changed my spark plugs. Well overdue at 118k miles. Was able to do it without removing the intake manifold. I don't think they looked too bad for that many miles.
Moved GMRC attenna to roof, added Meso puddle pods with switch, added rear chase lights with switch and attempted to rig up a high blinker system but using a four plug and going into the trailer hitch didn't work so I'm going to get some posi-taps and go right to the linestgoughts on puddle pods? I’ve been looking at them.
Switched out ditch lights to Baja LP4’s. Way better than. the Cali Raised.
Did have to switch mounting brackets. The Rago ones I had weren’t stiff enough. The lights bounced and flexed over every bump making the lights unsteady. Switched to SDHQ mounts. Rock solid now.
Backlighting looks bad ass!
Forgot I ordered this until it showed up in the mail yesterday, but SaBellCo tailgate lock installed. I installed the factory electronic tailgate lock when I first got the truck, but I'll sleep better knowing this is on there now just in case some jackass tries to steal it and gets thru the OEM lock. I also like that if I'm driving with the tailgate open for some reason there's less chance of it popping out of place and getting dragged behind the truck (however unlikely that scenario is).
