5.29 gears installed front and rear @77k miles. Feels great paired with the 35 inch tires.
Did you make the plates or buy them?Body mount chop
We made them. It was pretty easy, just made a cardboard template and cut them out of some steel sheet we had. We had to bend them a bit and once tacked into place we hammered them to shape and finalized the welds. Finished it up with painting the inside and out to prevent rust.Did you make the plates or buy them?
Did you order these assembled?5.29 gears installed front and rear @77k miles. Feels great paired with the 35 inch tires.
I did. Check out East Coast Gear Supply. They assemble the gears in used cores and ship them to you. When your done with the swap, you send your old ones back and they return your core fee.Did you order these assembled?
So I went with the Bilstein 6112 originally because it was the best performance shock I could afford at the time. They are great and feel amazing compared to the stock suspension.What made you make the switch to the Dobinsons suspension? Bilsteins have any issues?
I've got the DCLB too and right now suspension is the most difficult choice other than tires
I ended up switching to Dobinsons because over time I had added a bunch of weight to the front end. (Bumper and winch) which dropped the front at least an inch. Even after adjusting the Bilsteins to the max height. I could have put a heavy # spring on them to gain more height, but I’ve been lucky enough to now be able to afford higher end suspension and decided to give Dobinsons a go. I’ve been loving them so far and the fact that you can adjust the dampening and rebound is a game changer. You can really feel the difference.
Yes, I had the front coils set to the max height setting. After adding the weight to the front, the loss of lift height was very noticeable . I was looking into heavy springs to offset this and regain the height. Bilstein makes some for about $180. If you plan on adding weight to the front, I highly recommend going with the heavier spring to support the added weight.When you say lost an inch. Is that from 2.5" @ max height?
The front and rear gears from ECGS came out to $5k out the door with a front locker included which was about $1.2k extra. The core deposit was close to $1.9k so at the end of the day I paid about $3k. If you do just the gears and no locker, you’ll be at about $2k or less at the end when you get your core fees back.So I need the front and rear. What did it run you and how much was the core refund?
Website is blocked from where I'm at.
Not loud at all.how loud are those duratracs?
