Rompin’ Taco - OR 4x4 Long Boi 🌮
Beamtech LED headlights and brights. These puppies have no fans! Nice and quite!
7a316823-8e05-48c2-81d1-fbe420fc3bd7-jpeg.23258
Got an awning for the truck. The first addition to the rack. Went with the Ironman brand. Really well made. Can’t wait to put it to use!
Also, on an off road road trip I broke my center cap on one of my rims! Ouch! But got them replaced with Meso Customs.
New updates:
picked up some maxtrax in turquoise and made custom mounting brackets for the Prinsu only cost about $15 for the supplies to make the brackets out of aluminum angle iron. Also, I had to adjust the light whip to match the new maxtrax.
Did some maintenance recently at 70k:
  • Oil Change (done myself for the first time after having the dealer do it every time) - on the filter cover someone had over tightened the drain cap so the whole thing came off and oil went everywhere. I now need to buy a new cap as I was unable to loosen the drain cover for future drains. I’ll also be getting a fumoto for future self service.
  • Greased the propeller shaft. Super easy to do.
  • Installed a bully net in the bed to act as a baby gate while tail gating
  • Installed some KC Rock Lights more photos to come
Suspension update: I had the front coils adjusted to max height. The truck is sitting pretty close to level now. I did have to take it to get an alignment which helped reduce just about all rubbing.
I've been a bit busy with buying a new house, moving and selling my old house and fitting in some upgrades to the truck here and there. So, heres a list of mods I've recently done to the truck.
  • OV Tune for 33 inch tires, 87 gas, and AGM battery update.
  • Rigid Industries D-Series Pro SAE Fog Light (Selective Yellow)
  • Southern Style Off Road Slimline Stage 2 Bumper
  • Square One Creations Frame Caps
  • Warn VR Evo 12s Winch
  • KC HiLights RGB Rock Lights
  • 12 Volt Socket in Bed with Volt Meter and USB Ports
  • Relocated KC 30" Light Bar behind the grille
  • Relocated winch controller behind grille
  • added spacers to emergency brake lines and flipped passenger bolt to prevent waring on leaf pack bolts
  • Greased the front UCAs and replaced a bad zerk fitting
Suregery/Facelift Excess Materials
New Garage space with room for a rooftop tent! oh yeah!
Ended up relocating the remote resi as I was experiencing a bit of tire rub on them while on the trail at full lock and flex. This should be a lot better.
