Winch access holes allow you access your winch mainly the neutral lever and have access to your solonoid if need beWhat are "winch access holes" used for on a front bumper?
I don't really know much about winches, but I assume you want quick access to these? or can they be accessed through the engine bay or underneath?Winch access holes allow you access your winch mainly the neutral lever and have access to your solonoid if need be
Yes, and yes you do need a access point as the grill assembly and bumper would block majority of the winchI don't really know much about winches, but I assume you want quick access to these? or can they be accessed through the engine bay or underneath?
I have a completely stock 2016 TRD Off-road. Will the stealth custom series F5 wheels stick out further than my stock wheels? How much more for each offset available.
This has probably been beat to death but I have a lift question....
I don't plan on doing any serious off roading in the truck. Mostly daily driving and hauling 4 wheelers with possible "light" trails. But I do want to raise the truck up and put some bigger/aggressive tires on it. I also don't want the ride quality to suffer from any of it.
I have a friend that swears by Bilstein and advised the 5100s in the front and back while also adding a 1in block in the back to help keep it level. That kit says 2in lift which to me doesn't sound like much. I have read lifting much more than that would need to start upgrading other suspension parts. Which I would rather stay away from for now.
So finally to the question. Is 2in lift worth spending the money on? And are the shocks the better avenue over something like ready lift (spacers and blocks)?
What’s up all!
I’m pretty new to the forum, like a couple of days new and I’m liking everything I’ve seen.
Anyone have any recommended methods on de-badging?
Need some suggestions for tow straps. Or snatch straps. Which one is more versatile? Thanks
Heres my stupid question. I have a 16 DCLB with a shell (bro lean) and sliders, which is basically going to be a DD, with only mild OR and foul weather mountain winter driving. So my issue is how to deal with the incessant hunting of the transmission. I am leaning towards 4.88's, but another issue is the delayed transmission engagement when descending a grade in second, theres a stall before the trans reengages. Also it takes a lot of throttle pedal travel before the thing goes, and near whiplash when it catches. Typical complaints. I had the TSB 0058 done but it didn't do shit. Maybe if someone can comment on my options. They are:
1. Gears may work, but will that lead to other mods? Running 32" now, I run at 75 on highway if that turns out to be too low, may have to go to a larger tire. That means a lift.
2. I like the stock ride now and don't really want a stiffer ride, so would the 1" front spacer and rear AAL and/or 1.5-2" block work? If not advised Id consider the best way to level the truck with minimal lift. I run Toyo AT 265/65-17 and would not want to eventually go larger than 265/75-17, I think that is the largest number to go without a major lift. (cant go too high, wife has issues getting in and out).
3. As far as shifting issues, Im not so sure the gears would solve both issues. It may stop the hunt, but that wont help delays in shifting Im sure, so that brings up the OV tune or Ive read about this SSP kit that alters the TPS inputs to the trans control module. Can anyone with experience with these issues comment?
Thanks for any inputs.
Snatch straps and tow straps are entirely different. Snatch straps are designed to stretch and absorb then transfer the dynamic load of a snatch recovery to the vehicle being recovered.
Tow straps are not designed to take the impact of a dynamic recovery and may fail of used that way. The are designed for non impact tow operations.
I carry a snatch strap and it has been quite handy and I have used it for both snatch and non impact tow recoveries.
Any recommendations on brand or length?
I’m looking at putting together a complete tool kit to keep in the truck. I’ve searched around the forum and can’t seem to find a thread, if there is one can someone point me in the correct direction, if not I can start a thread so we can get everyone’s input on tools they carry down trail
I just keep a cheap harbor freight toolkit in my back seat. I’d probably add a breaker bar too if I wheeled Hard. But I used That little kit to put my rock sliders on the my tonneau cover and lights and light bars too. Harbor freights the way to go for stuff like thatI’m looking at putting together a complete tool kit to keep in the truck. I’ve searched around the forum and can’t seem to find a thread, if there is one can someone point me in the correct direction, if not I can start a thread so we can get everyone’s input on tools they carry down trail
Harbor freight hand tools are awesome, power tools....not so muchI just keep a cheap harbor freight toolkit in my back seat. I’d probably add a breaker bar too if I wheeled Hard. But I used That little kit to put my rock sliders on the my tonneau cover and lights and light bars too. Harbor freights the way to go for stuff like that
Yeah power tools I gotta Go with Milwaukee. And anything with impact like chisels I’ll spend the extra money on for something good. But for the truck I got the 99 piece kit that was like 30 bucks or around thereHarbor freight hand tools are awesome, power tools....not so much
Any rated straps will work fine. I have a 30' Smittybilt, but there's plenty of others.
I don't think we have a thread like that. Would definitely be a good one to start. You could make a what's in your tool kit post. It could be quite handy for others.
Up until i bought my 19 Taco in April I had never been involved or even been in a 4x4 vehicle.
2 Noob questions.
1- What is the purpose of a snorkel in any truck?
2- What is a locker and how do you use it? I've read the terms "air locker", "electric/electronic locker", "mechanical locker"??
Thanks.![]()
I’m looking to upgrade my Fogs with Baja Designs SAE but I’m worried it will blind other drivers on the road since my fogs are higher than stock due to my 3” lift. Has anyone experienced any issues with upgrading their fogs on a lifted Tacoma?
My truck has a ceramic coating on the paint. If I remove the bed-side decals, will it be obvious there’s no ceramic coat? Do I need to get it redone at that point? She’s already covered in pinstripes so I don’t think that’s the answer. Trying to determine if there will be an obvious rectangle where the decals once were.
If I were to buy TRD Pro lights, what would be required to shove them in my sr5? sorry, I'm an electrical moron...
I can ask my friend who does professional auto detailing and ceramic coating and get back to youMy truck has a ceramic coating on the paint. If I remove the bed-side decals, will it be obvious there’s no ceramic coat? Do I need to get it redone at that point? She’s already covered in pinstripes so I don’t think that’s the answer. Trying to determine if there will be an obvious rectangle where the decals once were.
I would venture to guess that the SR harness is terminated at where the LEDs would plug in. Most mfg'ers make one harness and terminate them on vehicles that dont have those options. It would be cost prohibitive to make a variety of harness' for different trim levels. At least thats what I have seen over the years.I'm honestly not sure if you'll have the outline of the sticker in the ceramic coating. I'd call the place you got it done and see what they say.
Not sure. I don't know if the factory SR5 harness has the wiring for the LEDs.
I talked to my friend about your query. He said that you would be able to tell where the stickers were...especailly when its wet. He said when its dry and clean, you would most likely need to be looking for it to see it, but if its dirty or wet, easily noticeable. Hope that helps somehow.My truck has a ceramic coating on the paint. If I remove the bed-side decals, will it be obvious there’s no ceramic coat? Do I need to get it redone at that point? She’s already covered in pinstripes so I don’t think that’s the answer. Trying to determine if there will be an obvious rectangle where the decals once were.
