Man Of Steel TRD
When would you have time?We can probably knock it out this weekend if you want!
That is the one I keep putting in the cart and taking out. Think it would be perfect as I need a place for the spare.Cb
Cbi?
That’s what I did. High clearance swing out. Didn’t do the table or anything gonna mount rotos on itThat is the one I keep putting in the cart and taking out. Think it would be perfect as I need a place for the spare.
Looks really good man! We must've been busy hacking my truck up while you were busy with the bumper.
Yeah eventually I'm going to do a U-bolt flip. I plan on ordering it from Wheeler's at the same time I get my SuperBumps. Just trying to let the wallet cool off for a while.Josh are you planning on doing a u bolt flip too? Or those staying the same
This is what I put on over the foam and just feathered it out from there. It goes on nice and thick and is heavily textured so you have to make sure you don't get it anywhere you don't want it, but it looks perfect inside the fenderwell. Also, I kinda freaked out because it goes on brown when you first spray it so I thought it was going to look like ass, but it dries to a nice matte black and blends well.I like the idea of filling in those gaps. I’ve lost so much inner fender plastic that definitely has left some areas for road scunge to collect, and it’s made paranoid about rust.
What did you use to spray over the foam? Stuff you get from Home Depot?
Thanks! I'm happy with how it turned out, and freed up way more tire clearance than I had with the last truck despite having flares because I didn't do the plastics and pinch weld right the first time on the '16. Avid did a more aggressive chop this time around also. Hopefully trimming and rubbing will be minimal from this point forward... I'm going from a 31.7" to a 33.9" tire so I'm going to need every bit of it.Going to be beating my pinch weld flat on Saturday. Got some flex seal and auto sealer to use.
That looks very nice!
Haha! This solves a lot of problems for us:I guess that means no more swamp ass.?
Yeah, I have no room for recovery tracks now, unless I figure out a way to mount them underneath the bed rack tubes somehow... a bummer for sure, but I can count on one hand the times we wished we had traction boards and we need water constantly, and pressurized water is even more useful so if this thing is half as awesome as I think it'll be, then we're in good shape.I wish I had that much bed rail real estate left. that thing looks awesome
The foam did exactly what I wanted and filled in all of the gaps so now I don't have to be paranoid about packing the voids full of rocks that will rattle, mud that will never wash out, snow and road salts that will rust, water that might find it's way into the passenger compartment, etc.
Tie rod looks ok to me but the angle on the lower ball joint does look funky. Your CV angles are steep but not terrible depending on the amount of lift you have. My truck isn't lifted right now so I have nothing to compare your angles to at the moment. @JerryTaco2.0 what do you think?OuTkAsT, could I get your opinion on my truck. Do you think my CV axle, tie rod and lower ball joint are at a funky angle? The ball joint sits kinda cock eyed. Or am I just being overly paranoid?
Not looking to hi jack your thread, just value your opinion.
Yeah you're missing a lot of liner in there, more than mine it looks like. I think (but don't yet know) the spray foam should be a decent long-term solution. It sticks really well to whatever it's applied to and has a decent amount of elasticity so there shouldn't be enough vibration or movement in those parts to deteriorate it too much over time, plus the rubberized undercoating is also fairly elastic and should help to preserve the underlying foam. This is all theoretical but I've used it a lot on things that see vibration and heat cycling (water pipes, ductwork, etc.) and it seems to hold up well over the years.One more item to get your opinion on.
I’ve lost a lot of inner fender well and was thinking of filling in the gaps with some backer rod, then foam spray like you did, then finish it off with some of the spray in the above quote. Do you think that would work, or would there be too much vibration and it would eventually break apart?
I apologize if the pics kinda suck.
I'll find out for myself how the 34" tires are going to rub after they go on next month. I got as aggressive as I could ahead of time so hopefully it's not too bad but there's just no way of knowing until they're on. My UCAs also have a lot of caster adjustment so I might play with that also before heading to alignment. Time will tell.I’m not sure exactly how much lift I have over stock. With the wheels I have it’s difficult to get an accurate center of hub to bottom of fender measurement. But I have 12 threads on the driver side and six on the passenger. For what that’s worth. It sits at least two to three inches higher for sure.
If @JerryTaco2.0 or @hellppy xould shed some light since they are both running the same size tire as me would be great. Or anyone else who knows for that matter.
I’ll try the foam and see what happens. Yes, got a little carried away on the fender trim. The tires are tearing the shit out of the plastic. It won’t be long before it’s trashed.
Thx again.
No I sold the factory wheels and tires together and replaced them with these.Josh did you have those 265s on the factory rims at all?
Detailed the truck last night, and almost exactly 35 minutes later we get an epic storm.
