- Joined
- Jul 2, 2021
- Messages
- 909
- Reaction score
- 2,290
- Age
- 40
- Location
- Ozark, MO
Blazing Blue Pearl
The new cover looks awesome!
Thanks man! I like it a lot!
Thanks again!Right on!!
On another note, got my socket in. I didn't take any pics of the install . I fought back and forth with where to install. I ended up installing in the center console. The main reason for that, I have a hard enough time seeing at night. This socket I ordered has a volt meter, which anytime the truck is on it's bright as shit. Popped up the center console, slide out the oem socket. I tried like hell to use the oem connector, but the connecter was at 90 degrees. The socket I got the terminals run parallel. Ended up chopping the oem connector off, using the supplied terminals. Also had to dremel out the socket hole just a little bit. I debated on running a cord up to my phone, but that would have required me to drill a hole for the cord to pass through. Buttoned it up after that. Simple install, although I'll probably order a Blue sea one for the lower console as I thought this one was a fast charge. Pro tip...it's not. I'm disappointed, but I hate returning stuff. Emailing a wheel vendor today to see if the wheels I am wanting are in stock
