cambo139
What is the largest size spare tire that a 3rd gen can carry?
I've heard of plenty of people fitting a 285/70/17 in the factory location with a little shimmying of the tire while placing it. Some people do some minor trimming but I've heard from a few that didn't need any.
It can be done but it isn't simple. You'd need to modify your exhaust and the tire mount itself and whatever else needs to be cleared, but people do it. You could also get a hitch mounted tire carrier if you aren't ready to fully commit to a new bumper.So has anyone with a 285/70 spare got it to fit in the OEM location? I just dry fitted mine and NO. It touches the differential, exhaust and the drivers leaf spring shackle. Fricken' mess. How in the F do you get this big ass tire to fit in the OEM spot?? UGH!
I currently have it strapped to the inside of my bed. Read: no room in bed for camping stuff. I have a bed cover so, setting it vertical isn't an option. Either put back in bed, or get swing out bumper. I'm in SoCal so would love to travel to see someone's same size tire in their OEM spot...
What is the best option for exhaust? Is it possible to cut the factory after the muffler and dump it down, or is aftermarket needed to do that?
I have a 35 x 12.5 under mine. Exhaust dumps after the axle and I run the tire without air. Some hammering was necessary, diff just touches the tread at full bump
Did it work for you?I’m gonna try and fit a 315/75r16 over the weekend. From looking at Robs vid there is a little centering bracket I’ll have to trim so tire might not be as stable side to side.
Like 2-3 PSI. It might just fit with 15 psi in it, but it's way easier to hoist into place with super low air pressure.Is that without air as in you set the bead when you need to pull it out? Or 15psi or so?
Do you have pictures?I fit a 285/75/16 no prob- still had an inch or more clearance from exhaust
I have 285/70R17 KO2's and I actually tried to put the spare under last night, and while it technically fits, it's up against the exhaust heat shield. So I didn't feel comfortable with that and just put it in the bed. I might try some exhaust chopping because I'll be adding a lift kit soon so I won't be so worried about ground clearance. I'd really prefer to get the tire out of the bed because it's taking up a lot of space I can put camping gear in.
Regarding cutting the exhaust to make it axle dump, are there any drawbacks? I did some Googling on this but most of the results are for diesels and their noise levels. Would this make a gas truck much louder? I'm thinking about my next set of tires (a little bigger) and possible exhaust reroute so doing this at the same time would make sense.
Dang, looks nice. Wonder what I'll do with that sweet black exhaust tip the dealer put on it though...Like axle dump? You could fit a biccboii under there!
The first pic the guy threw it on. Lol.Dang, looks nice. Wonder what I'll do with that sweet black exhaust tip the dealer put on it though...
Asking for under carriage pictures. Someone's naughty.Do you have pictures?
