Krose70933
Will 265/70R17 fit on a 17x9 rim with -12 offset on a stock trd pro
Nice truck! I'm interested on a 2-2.5 inch lift with 285/70/17 along with the Prinsu roof rack. Question is, how much lift do you have and how much room do you have left up top to park the truck in the garage. Assuming that you have the standard garage height.
Thanks! Good to know there's plenty of space.I have a about a 2 inch lift.. I'm running the icon 2.5 up front but didn't crank them to get the max lift. with my prinsu there is plenty of room to fit under the garage opening (standard). I also run a Plano case and front runner awning on the prinsu mounts and still have about 3 inches to spare
What is the offset on those wheels?I've got the Low Range Offroad 3" packaged lift. Everything you need in one box. 17x8 rims with 285/70/17. No rubbing at lock or over bumps.![]()
Question to anyone with experience in the matter. Should I get P285/70r17 (4 ply). I’m going to be running trd pro 4runner wheels and a full ome 2 in lift. Plan to add bumper, sliders, skid plates in the future. I am hesitant to buy 10 plys simply because of the weight, but there don’t seem to be many 6 ply options other than Bfg’s which are a tad pricey imo. Sorry for the long post but I look forward to hearing what you guys have to say!
Any rubbing issues up front??![]()
Mine are -12 with 285/75/16
At that size you will be okay. If anything, OVTune will help a lot, which is cheaper and easy to install yourself. I had 285/75r16s on my stock gears and it felt fine. When I went to 35s they didn’t feel THAT bad, but I did regear to 5.29s.Question for you more knowledgeable folks out there: At what point do you have to worry about regearing with regards to tire/wheel size? I have 19 TRD Sport and have been wanting to get a lift and add 285/70R17 and just want to make sure that I'm good here.
Got a pretty aggressive CMC. No rubbing so far. Yet to full stuff the fender. I’ll see tomorrow when I hit the trail.Any rubbing issues up front??
I think it depends on where you are at(elevation and driving conditions). I absolutely hated our truck on that tire size and stock gears. But we are at 6k feet and pretty much everything is uphill from us. YMMVQuestion for you more knowledgeable folks out there: At what point do you have to worry about regearing with regards to tire/wheel size? I have 19 TRD Sport and have been wanting to get a lift and add 285/70R17 and just want to make sure that I'm good here.
I think it looks really nice with stock bumpers. Sometimes I wish mine were stock but with the 35s.If anyone wondering about 35x12.5 ET -38 with stock bumper (anyone dumb enough to try this?). Minimal rubbing depending on terrain.
-3” lift
-cmc
-front liners pulled ahead
-solid alignment (can’t recall specs...)
Wont be stock for long! Almost a 6 month wait for a C4 hybridI think it looks really nice with stock bumpers. Sometimes I wish mine were stock but with the 35s.
I know the pain. I waited around 7 months or so for my rear bumper.Wont be stock for long! Almost a 6 month wait for a C4 hybrid![]()
I had the same tire size on the stock wheels. I only rubbed in the cab corner and top of the fender while flexing. But I cleared the UCA, which is the important part. I had SPC aftermarket UCAs for this.I need help, i just completed a 3 inch lift kit on 2017 TRD off road Tacoma. It was lifted 3 inch in the front and 2 inches in the rear. I'd like to go with the Nitto Ridge Grappler 285/75 16's to put on my original OEM wheels. According to specs these tires measure 32.83 and 11.26 wide.
Will these rub, i don't want to trim or cut. Will I need spacers?
Please help!
What UCAs do you have? If they are stock, you will rub them.
I recommend upgrading the UCAs since the truck is already lifted and the stock UCAs are known to not hold up well on a lifted truck.The UCA's are stock. What size spacers do you recommend?
