You heard it here first. rob will be going to 35s.35+ are cool but regearing is a must and I'm not there yet with my budget...I won't say never though.![]()
6 inch 37s ?![]()
I've got 285/75's and to be honest, I kinda wish I went with 35's. Obviously though, there's a big difference it what it takes to run the 35's. You've gotta consider all the cutting, CMC, big drop in gas mileage, regear, driveshaft angle, etc. With my 285's, I didn't really have to do much besides replace my UCA's and now I only rub at full flex. I want to commit to the 35's, I just don't know...
Also, is it just me, or do you wish there were a 35 that is thinner than 12.5". I feel like 10-11" would look sweet.
I’ll keeo this in mind for whenever funds allow me to do this.It isnt as much work as you think and if you every want to go over the details of it on a 3" vs 6" we have done both including bushwackers as well. I would be happy to go over what we did!
HAHAHAHHAALOL no. my back can't handle it
Maybe a 1/2” spacer above the strut?As some of you may already know, I went with 315s. Not 35s but close enough. My tires measure to 34.4 inches. I’m still having some rubbing issues on the cab mount even after the cmc and adjust the casters to as much positive as possible. My kings are set to about 2.75” height. My wheels are 0 offset. Anything I could do or change that’ll help eliminate this?
I thought that spacers were “bad” for the truck though?what about adding top hat spacers to the top of strut by headstrong.
they sit on top of the strut so it doesnt effect it whatsoever.I thought that spacers were “bad” for the truck though?
This isn’t the spacer that is “bad” for the truck. We all have them anyway to fix the Taco lean our trucks get. If you don’t have one at all yet, that’s actually a good thing cause it means your strut studs will be long enough to add these on.I thought that spacers were “bad” for the truck though?
What you’re thinking of is a spacer lift, which is using very large spacers to actually lift the truck without needing to change coils or shocks. That is done mostly for looks and is essentially useless.
It’s a pain in the motherfucking ass that’s for sure lol excuse the language. It’s a lot of trial and error for sure, and with is also a lot of wasted money. Once I get everything sorted out I hope I can guide the hopefuls in the right direction so they don’t spend so much money like I haveI want to run 35’s but after reading a lot of these comments and cost to run 35’s I think I’m ok with 33’s.
If you are going 17” you have the 34x10.5 option. Not sure if those are actually a little bigger or not.I dont think Ill go 35’s but seriously considering 34’s. Specifically 285/75/17’s. All I would need is a CMC amd those are only 150$ around SoCal
about half an inch as the 34x10.5 (also comes in the 255/85R16) is 34.5ish depending on the tire where the 285/75R17 is about 33.8ishIf you are going 17” you have the 34x10.5 option. Not sure if those are actually a little bigger or not.
So what springs did you go with in back to get 2.75, and did you have to get the lengthened piston rods on the rear shocks to support?As some of you may already know, I went with 315s. Not 35s but close enough. My tires measure to 34.4 inches. I’m still having some rubbing issues on the cab mount even after the cmc and adjust the casters to as much positive as possible. My kings are set to about 2.75” height. My wheels are 0 offset. Anything I could do or change that’ll help eliminate this?
Ouch! What's your gas mileage down to?Well my KO2s are really 34.4 inches tall. They’re not true 35s but I still call them that. Plus the tire is huge and weighs a massive 63 lbs w/o the wheel.
16-17 isn't bad. That's what I'm at (mix city/hwy) running stock gears and 285/70R17.To get the added height in the rear I went with the OME medium duty leaf pack with extended rear shocks. Still waiting for rear kings to arrive so for now it’s just bilstein 5100s in there.
And my mpg before the regear was 13mpg average. Now it’s at 16-17 mpg.
Did you order the King 25001-121 or the ones with the pistons that are 1.5" longer that the -121? I'll be interested to see what the travel is on your kings once installed. I have the 25001-121 extended travel, but not the 1.5" longer pistons. So I'm looking to add a new spring set to get to your height.To get the added height in the rear I went with the OME medium duty leaf pack with extended rear shocks. Still waiting for rear kings to arrive so for now it’s just bilstein 5100s in there.
