Pinch weld
haas.evan
I've just fitted 285/75/17s on my truck with an Icon stage 4 lift. The CMC and fender trimming is done as well. The last real thing I need to do is the pinch weld. That being said does anyone have any tips on how to bend the pinch weld out of the way?
Just hit it with a bfh. The top part is very easy to bend, once you get lower you have to swing a little harder.
Bend it towards the outside and you can use it to mount the fender liner to it.
Heres my video on it, how I did it.
SAVE YOUR PINCHWELD 3rd gen Tacoma cmc
Original link: https://youtu.be/jZyyAQocu2M
Use a grinder, sawzall, tin snips, etc to cut the pinch weld every few inches where the contours are so when you hammer it down there is relief in the areas where there are any bends or contours.
Pro-tip: Use a drilling hammer. 3lb should be good. Makes a huge difference. Heat it and go slow. Even can wrap the hammer with a towel.
Don’t take this as rude but
Wut? I’ve been analyzing this statement for a few minutes and phoned a friend, I just don’t get it.
So use a drilling hammer? Hammer drill?
3lb one is enough
Heat the drill or the hammer?
Wrap hammer with towel, won’t it be too hot?
I just need answers..
Estwing 3-Lb. Drilling Hammer (aka BFH).​
