The 5100 are adjustable, yes. The OME 887 are the coil brand and type. The coils are the springs that go around the Bilstein shock. So essentially buying this coil will give you the leveling you're looking for (because it's longer than your stock ones) and the 5100 shock replacement is to ensure you get maximum travel/don't push your stock shocks too far.Sup man very new to this so the truck comes with bilstein shock so 5100 would be adjustable? I don’t know what 887 are, would this be only for the front?
It would depend on the size of the spacer used.How well would this setup work with 285s?
Tyler thanks for the info i also see that a lot of taco setups have the add a leaf do i have to do that or can i just install shocks and coils????
Just to add, replacing coils and shocks are generally a better ride from stock. After I did my setup I had less body roll (better handling), and better “comfort” over bumps. That’s in addition to the extra height/travel. I also replaced my leaf pack rather than just doing AAL, though. And I don’t even have the nicer Kings/Icons he was talking about.@Ktmslado Damn, that's exactly the info I needed! Thank you for taking the time to write that up, easy to understand and very informative.
Checking out what you have listed now...
