Finally upgraded my tires to pizza cutters
CementTRD
Well finally have enough pennys to get the tires I wanted!!! 255/85/16 cooper st-maxx!! Who else is rocking them?
For those interested, I recently installed a set of 255/80/17 Toyo Open Country A/T III with TRD Pro wheels on a fully stock 2019 Sport (no lift). Photo is below. I've also attached a writeup for those looking to dive deeper.
TL;DR - with this wheel/tire combination, there was no rubbing at ride height, but the clearance is close. You'll probably want to do some very simple trimming and molding of the fender to make a bit more space just to avoid the issue. Clearance to the cab mount is fine - no chop needed. Did a stuff test and tire clears cab mount by at least 0.5 inches. Increased ride height by just over an inch. Very happy with the results.
The pizza cutters look good I just wish there was a 35” pizza cutter in a tire that isn’t a super swamper.
Tyler, check with Lord Humongous about skinny 35s. If I recall correctly I'm pretty sure he was running a set that weren't Swampers.
Since that post I have moved onto regular 35s and now 37s are in my future so pizza cutters will have to wait. Thanks for the heads up though.
