* Patent # D820,180 *
Bed Stiffeners - What do they do? Do I need them?
This is a very common question we get at TOTAL CHAOS. If you're running a camper shell, bed rack w/ RTT, or just putting your truck through serious off-road abuse then you should consider Bed Stiffeners.
On 2005 and newer Tacoma's the composite bed is very weak. Unfortunately for the 2016+ it didn't get improved. Over time they can fracture or crack causing issues with tailgate alignment and possibly lights. We reinforce the rear bed channels at the tailgate which is ideal for preventing bed flex and avoiding issues that come along with it.
The TOTAL CHAOS Bed Stiffeners also feature additional tie-down points. Adding a set will give you 6 tie down points and 2 light or whip mounts. *no load ratings are implied
Constructed of 3/16" steel these are built to last. We finish them in a durable black powder coat and include grade 8 hardware for the install. Are you running TOTAL CHAOS Bed Stiffeners or have questions about them? Post up
2016-2018 Tacoma - HERE - $170.83
#48676
INSTALL INSTRUCTIONS
TOTAL CHAOS
WWW.CHAOSFAB.COM
#48676
TOTAL CHAOS
WWW.CHAOSFAB.COM
