You will be fine with this size on stock rims. I have 285/75 on stock and it’s fine. Since you’re getting new 17’s, it’ll be even easier for you.Found a great deal on 275/70/17, read that I need to watch back spacing to
Make sure it doesn’t contact stock uca. I have 16” now so I will Be going with new rims.
Any input would be appreciated
Brian
Any rubbing issues with 285/75s? I have 265/70/17 with a Stage 1 lift kit with stock UCAs and I’m looking to upgrade to bigger tiresYou will be fine with this size on stock rims. I have 285/75 on stock and it’s fine. Since you’re getting new 17’s, it’ll be even easier for you.
With my suspension setup, only while offroad and turning/stuffing at the same time. It is tolerable for now.Any rubbing issues with 285/75s? I have 265/70/17 with a Stage 1 lift kit with stock UCAs and I’m looking to upgrade to bigger tires
Did you have to undergo a Body Mount Chip or no?With my suspension setup, only while offroad and turning/stuffing at the same time. It is tolerable for now.
I haven't done the CMC, no. I won't need it until I go to 35's.Did you have to undergo a Body Mount Chip or no?
