Work Wheels S1HC Official Thread!
ShowstoppersUSA
Glendale, CA
Work Wheels has created a 6 lug offering for us. Fitment is ideal and is perfect!
Feel free to ask any questions, along with post up photos if you have purchased a set!
Work S1 HC wheel specs:
  • Colors: Matte Gun Metal - Dark Bronze
  • Size: 17x8.5 -10 6x139
  • Center cap: Optional (Polished)
  • Weight: 24 lbs.
  • Construction: Gravity Cast Technology
  • Strength: JWL certified
Inferno/Gunmetal - 2in lift w/ 285/75r17 Cooper At3 XLT
Cavalry Blue/Bronze 3in lift w/ 285/75r17 Cooper At3 XLT
White/Bronze / 315/70/17 on 2.5" lift.
img_20190814_205610-jpg.3484965
15047
img_20190814_205203-jpg.3484966
Some updates with the wheels
  • Weight: 24 lbs.
Hello how did everyone install the center caps? I just got a set of these wheels in matte dark bronze but I can’t figure how to install the center cap. Any help will be greatly appreciated!
Usually there will be a retaining ring or pressure fit with o-rings. Some have spring clips. You just push it in. Sometimes they have spring clips. Spring clips should hold onto the wheel. The O-ring will prevent movement.
If it's tapered, it might need to be installed on the wheel before installing the wheels on the vehicle.
After a quick search, it does seem like it is supposed to be installed from the inside. If that's the case that's awesome. So no one can steal them. Might be designed that way since they are truck wheels. From the inside is the only way I see it fitting.
Did you purchase the correct center caps ?
Post a pic of the back of the center cap and the size of it compared to the opening.
Now I hate you. I talked myself out of grabbing center caps for my Volk TE37X's because I thought they were just pressed in and people would steal them.
I had an iForged center cap stole from me.
Source: https://www.youtube.com/watch?v=3afN2nf2mBg
It looks like they are installed from the inside, so you can't just pull them off. They are pushed in from the inside.
Now I need center caps... Shit. Now I'm obsessing over this. Emailed 2 places. Tried to call one. I'll report back if I figure it out. Now I also need to replace my Rays lug nuts with the Straight 42 type. I hate you.
