Wheel Spacers
ppaluigi
1.5 inch spacers will be installed on my 21 Tacoma. Have there been reports of decreased turning radius?
Depends on your wheel/tire/lift set up. Stock should be fine. 16x8et0 + 265/75/16 + 1.5" Spidertrax with 2.25-2.5" of lift rubs slightly even with a CMC and folded pinch weld. Rubs slightly on the sway bar even with the relocation kit. But doesn't reduce radius. You'd have to go chonky for it to limit your turns.
Will depend on how flush your tires sit from the fender line.
