What's Your Suspension?
  • Thread starter Thread starter Ron
  • Replies Replies 99
  • Views Views 17K
Front is a 6" BDS lift with Fox 2.5 coilovers. Rear is a BDS add-a-leaf combined with a 3" block to help deal with the weight of the RTT and gear, or towing the camper. I've been very happy with the lift thus far (y)
I need better pics of my suspension. Some killer serious in here.
OME BP-51 front and rear.
Dakar HD springs
Superbumps front and rear
SPC UCA's
Do your Dakar leaf springs squeak like crazy when they get wet/dirty?
Oooooh yeah. I just had to lube them up yesterday. I've read a few things online regarding an ARB specific TSB on how to address the squeaks but I have yet to fully do the recommendations. Soon enough I'll get to it.
What exactly do you mean by ARB specific? It’s what they reccomend for their product but you plan to apply it to the Dakars because it’s the same concept?
ARB owns Old Man Emu. So the TSB came from ARB and is for the OME Dakars. I have it on my tablet, I'll see if I can post it here later.
Hi everybody! New to the page! Came across this thread and thought I’d share my rig :giggle:
2016 Tacoma TRD Sport 4x4
-IconVehicleDynamics 2.5 Stage 1 Lift Kit
-MethodRaceWheels NV 305 17x8.5
-Fallen WildPeak AT3W 265/70/17
The last picture is how my rig currently looks, I removed the plastidip from my fenders due to someone clipping and stripping the dip off one of my fenders
thinking of going with this kit, would you happen to have your hub to fender measurements? also how much did you set the coilovers?
Icon ext travel 2.5” coilovers with ext. resivior and CDC valve ADJ. and my stock fox 2.5” piggyback res. With OME Dakar HD pack
Bilstein 5100 front and rear
OME 887 coils
Light Racing upper control arms on stock setting
Taco lean spacer but it’s not enough
Dakar HD heavy leaf pack
285/75 BFG KO2
Great lookin' setup. Curious what made you go with the HD Dakar leafs? I'm looking at the same setup you have on Headstrong Off-Road. It looks like OME suggests getting the HD leafs if you're constantly running up to 660 extra pounds back there. I'm curious if the HD leafs change your suspension to a tougher ride enough because I'm also considering getting the HD's since I have a camper and sometimes haul loads upwards of 1000+ pounds which is close to pushing the max payload rating.
I'm also about to replace my front bumper with CBI's full grille protection (once it finally ships) and weld on some additional horizontal bars for added protection; lots of deer here in Colorado! So I was looking at getting the 886 springs on the shocks for the 660lbs spring rate (bumper is about 140lbs). Doesn't look like those springs are an option on the dropdown menu they have, but I'll ask anyway. Will probably also do the second-to-last setting on the shocks like you have for the maximum lift.
Being primarily a weekend warrior + hunting/fishing frequently, I think this suspension setup will be perfect for me and will give me every capability I need without anything extra I don't need.
Lastly, haven't looked too much into fixing the lean yet for the driver's side. Any suggestions on how to negate that? Thanks!
I found a kit for under 1500 that offers 3" of lift...but no AAL... it's a joke right? Like... there's no sense on buying it.
I am thinking of getting the Headstrong Offroad package of Billstein 5100s all around with OME 888 coils and single AAL for the rear. I want to add lights racing upper control arms so i can eliminate any alignment issues.
I have a 2017 TRD sport double cab. I dont do any offroading right now. Just a daily driver. When i had my 2012, i put on the ReadyLift 3"sst kit and it was a rough ride. I am looking to spend a little more money and get something better.
So my question is will i be able to fit the tire/wheel size combo im looking to get???
I want 285/65/18s.
Looking to get Fuel 18" (-12 offset) wheels on toyo open country all terrains
I want 285/65/18s.
Should be good with that setup what's the backspaceing on the rims?
Current Suspension setup:
King 2.5 EXT w/ Compression Adj. - 700lb spring
King 2.0 Compact bumpstops
Deaver U402 Stage 3 Leaf Springs
Kartek Limit straps (rear limit straps have since been moved compared to photo)
All the gussets (Coil bucket, spindle, marlin crawler LCA gussets)
Boxed rear frame
Ruffstuff Axle truss
Future:
Engine crossbrace being developed right now in junction with secondary bypass mounts
8" 2.5 King 3-tube secondaries up front soon, should handle the weight a lot better than with just the coilover on the dunes
For the rear Im excited to be updating to 2.5 King 12" 3-tube shocks hopefully in the spring.
...more gussets
Weld sliders to frame
Need to reinforce the radiator core support since that seems to be a weak point, tore the sheet metal on both sides where the fenders are held.
