At TOTAL CHAOS we want to make it easy to maintain your suspension components! Our Upper Control Arms (UCA) are designed to be easily greaseable without removal from the vehicle or an alignment afterward. With just a few tools and a couple minutes of your time, you can be greased up and ready adventure!
NOTE: Do NOT pump grease into a UCA without loosening thru-bolt. Doing so will most likely cause the bushing to deform and require replacement. Please watch the videos below on HOW TO properly maintain your TOTAL CHAOS UCA bushings and uniballs
HOW TO - GREASE YOUR TOTAL CHAOS UCA BUSHINGS
HOW TO - LUBRICATE YOUR TOTAL CHAOS UNIBALLS
THRU-BOLT TORQUE SPECS:
2000-06 TUNDRA (98ft/lbs)
2007 + TUNDRA (173ft/lbs)
1996-02 4RUNNER (87ft/lbs)
2003+ 4RUNNER (85ft/lbs)
2007+ FJ CRUISER (85ft/lbs)
1996-04 TACOMA (87ft/lbs)
2005-15 TACOMA (85ft/lbs)
2016+ TACOMA (85ft/lbs)
1998-07 100 SERIES LAND CRUISER (72ft/lbs)
2008+ 200 SERIES LAND CRUISER (136ft/lbs)
Want to know HOW TO Prep your TOTAL CHAOS UCA’s? We cover replacing Bushings and Uniballs in this thread:
https://tacoma3g.com/threads/total-chaos-uca-prep-replacing-bushings-uniballs-video.524/
Post up or give us a shout if you have any questions! Hope everyone is causin' some CHAOS this weekend!
TOTAL CHAOS
WWW.CHAOSFAB.COM
TOTAL CHAOS
WWW.CHAOSFAB.COM
