TOTAL CHAOS - Stock Length Lower Control Arm (LCA) - Should I upgrade?
TOTAL CHAOS
chaosfab.com
At TOTAL CHAOS we offer stock length replacement Lower Control Arms for a variety of vehicles. These are available in Standard and Race Series with single and dual shock offerings.
Standard - Stock Length Lower Control Arm
- 3/16" main body stock length fully boxed lower control arms are CNC laser cut and include internal gussets.
- Boxed arms feature replaceable urethane pivot bushings. Pivots include zerk fitting to maintain the equipment while bolted on the vehicle.
- 1/4" thick steel skid plate is integrated into the control arm for rock crawling protection.
- Features a billet machined uniball adapter. Lower ball joints are upgraded to a 1" stainless steel uniball for maximum wheel travel and added component strength.
- Dual shock capable or Jounce Shock compatible.
- Weld-on bump stop spacers are included.
*These arms will not fit on Hilux Revo or vehicles equipped with KDSS
*Not compatible with shocks with bushing lower rod ends.
Race Series - Stock Length Lower Control Arm (Single Shock)
- Racer inspired and constructed from 100% laser cut 4130 chromoly.
- The lightest weight bolt on lower arms @ 16.5 pounds.
- Maximizes vehicle ground clearance with integrated lower uniball cup.
- Single shock tab mounts do not require wheel spacers to be installed.
- 1" 100% stainless steel uniball replaces factory lower ball joints.
- Replaceable polyurethane pivot bushings include zerk fittings for easy maintenance.
- The lightest weight bolt on lower arm @ 16.5 pounds.
- Dual 2.5 shock capability provides maximum dampening control.
*1.25" wheel spacers are required.
Toyota Tacoma
(2016-2018)
Standard - Race Series (Single Shock) - Race Series
(2005-2015)
Toyota 4Runner
(2010-2018)
*** KDSS Compatible ***
Race Series (Single Shock) KDSS - Race Series KDSS
(2003-2009)
Toyota FJ Cruiser
(2010-2017)
(2007-2009)
Lexus GX460
(2010-2017)
Lexus GX470
(2003-2009)
Toyota Tundra
(2007-2018)
Race Series
Toyota LandCruiser 200 Series
(2008-2017)
Race Series
Not sure if you should upgrade?
Please take a look at the following posts for more information on TOTAL CHAOS Lower Control Arms. Comment below if you have any questions.
TOTAL CHAOS
WWW.CHAOSFAB.COM
Part 1 ⁣
Why should you install a set of TOTAL CHAOS stock length replacement lower control arms?
Here are a few of the features and benefits built into the TC LCA's. ⁣
• Press ▶️
• Laugh ⁣
Part 2 is live and Part 3 is coming very soon!
CLICK HERE to see all TOTAL CHAOS Lower Control Arms
Part 2:
TOTAL CHAOS
WWW.CHAOSFAB.COM
Toyota Tacoma
(2016-2018)
(2005-2015)
Toyota 4Runner
(2010-2018)
(2003-2009)
Toyota FJ Cruiser
(2010-2017)
(2007-2009)
Lexus GX460
(2010-2017)
Lexus GX470
(2003-2009)
Toyota Tundra
(2007-2018)
Race Series
(2008-2017)
Race Series
TOTAL CHAOS
WWW.CHAOSFAB.COM
Would love to get on this, huge upside and benefits! Gonna look into selling a kidney on the black market to be able to get a set and finally get on that team @TOTAL CHAOS
Toyota Tacoma
(2016-2018)
(2005-2015)
Toyota 4Runner
(2010-2018)
(2003-2009)
Toyota FJ Cruiser
(2010-2017)
(2007-2009)
Lexus GX460
(2010-2017)
Lexus GX470
(2003-2009)
Toyota Tundra
(2007-2018)
Race Series
(2008-2017)
Race Series
TOTAL CHAOS
WWW.CHAOSFAB.COM
Will the race series LCA still mount properly if I have an upgraded UCA already, (isn't Chaos) along with the fox 2.5 remote reservoir DSC?
The LCA bolts directly into the factory location. Your UCA or shocks won't effect this. If you decide to run secondary shocks you'll need to purchase our shock hoops.
TOTAL CHAOS
WWW.CHAOSFAB.COM
So here's a question. I currently have an Icon stage 12, or something like that. So, extended travel coil overs and external bypasses. I like the idead of new LCA's however I am unwilling to sacrifice my turning radius as I often am on very tight trails containing very sharp switchbacks so I can't afford to lose any more turning radius. Do you guys have a solution? My experience with your race series lowers is that a significant loss in that turning tadius happened so I want to avoid that but gan some strength in the LCA department
You are correct that the turning radius is reduced compared to factory. It's something we are keeping in mind as we move forward and look for ways to improve our products.
TOTAL CHAOS
WWW.CHAOSFAB.COM
Which of these three products be most compatible with an Icon Stage 8 suspension lift?
