At TOTAL CHAOS we offer stock length replacement Lower Control Arms for a variety of vehicles. These are available in Standard and Race Series with single and dual shock offerings.
Standard - Stock Length Lower Control Arm
- 3/16" main body stock length fully boxed lower control arms are CNC laser cut and include internal gussets.
- Boxed arms feature replaceable urethane pivot bushings. Pivots include zerk fitting to maintain the equipment while bolted on the vehicle.
- 1/4" thick steel skid plate is integrated into the control arm for rock crawling protection.
- Features a billet machined uniball adapter. Lower ball joints are upgraded to a 1" stainless steel uniball for maximum wheel travel and added component strength.
- Dual shock capable or Jounce Shock compatible.
- Weld-on bump stop spacers are included.
*These arms will not fit on Hilux Revo or vehicles equipped with KDSS
*Not compatible with shocks with bushing lower rod ends.
Race Series - Stock Length Lower Control Arm (Single Shock)
- Racer inspired and constructed from 100% laser cut 4130 chromoly.
- The lightest weight bolt on lower arms @ 16.5 pounds.
- Maximizes vehicle ground clearance with integrated lower uniball cup.
- Single shock tab mounts do not require wheel spacers to be installed.
- 1" 100% stainless steel uniball replaces factory lower ball joints.
- Replaceable polyurethane pivot bushings include zerk fittings for easy maintenance.
- The lightest weight bolt on lower arm @ 16.5 pounds.
- Dual 2.5 shock capability provides maximum dampening control.
*1.25" wheel spacers are required.
Toyota Tacoma
(2016-2018)
Standard - Race Series (Single Shock) - Race Series
(2005-2015)
Toyota 4Runner
(2010-2018)
*** KDSS Compatible ***
Race Series (Single Shock) KDSS - Race Series KDSS
(2003-2009)
Toyota FJ Cruiser
(2010-2017)
(2007-2009)
Lexus GX460
(2010-2017)
Lexus GX470
(2003-2009)
Toyota Tundra
(2007-2018)
Race Series
Toyota LandCruiser 200 Series
(2008-2017)
Race Series
Not sure if you should upgrade?
Please take a look at the following posts for more information on TOTAL CHAOS Lower Control Arms. Comment below if you have any questions.
TOTAL CHAOS
WWW.CHAOSFAB.COM
