GaryEMoody
I am new owner of Tacoma. Next week I am planning a camping trip with this new ride. I want to purchase some good quality Tacoma Truck Bed Tents. Please suggest some good stuff.
100% agree. Truck bed tents fit in a weird area where they aren't ground tents or RTT so they don't have the benefits of either.I wouldn't do the truck bed tents. Grab a smittybilt roof top tent and some bed rails (or ratchet strap some 2x4's temporarily) and mount that on the back. Way better than an in-bed tent.
-It takes as much work to set up a truck bed tent as it does a ground tentWell, don't they still have the benefit being up off the ground? Sure, you're not 6 feet up, but at least you're not on the dirt. Maybe it isn't quite as easy to set up, but outside of that what benefits am I missing? Also, a lot less likely to fall and break a leg in the pitch-black night when you have to use the restroom.
Seems a lot more convenient to have a tent you can quickly pack away and remove from the truck without a struggle versus a rooftop that is always on the truck unless you want to put in some serious work taking it on and off. Alternately, you can get more space with an RTT (depending on the model) but is the space really needed? The tent is really only there to sleep in.
I ask because I'm planning a bed tent as well and really can't see any downsides.
-you'll still need a sleeping pad (truck beds aren't comfortable)
-you'll need to take everything out of your truck bed to place the bed tent in place
-Not much room back there. 5.5 ft long closed, maybe two people could lay down in a Tacoma bed with the tailgate down, tight quarters and no place to put stuff inside if it's just you and one other person.
I think if you're going to go truck bed tent, you aren't really gaining anything over a ground tent. Jumping up to a roof top tent over your bed allows for sleeping gear all within the tent, and so hastens camp set up time. It also allows you to keep your gear in the truck bed.
But hey, do the truck bed tent. Share pics.
In the bed tent can be had for $75 off Craigslist, RTT cost me $1,200. Much happier with the RTT as I don’t have to remove everything from the bed to setup the tent.
What version? In bed or RTT?Right on! Did you have any more pics of the tent during setup or use?
Also, side note, I'm weird and I like to try weird stuff!![]()
@itsthex, I have a Rightline Truck Bed Tent. I first purchased the midsize 6' long bed (item #110770) then exchanged it for the 6.5' full size (Item # 1878820001). The 6' version was too small and the zipper started to tear. The 6.5' version is too big. REI sells them for under $100. The first 2 Pics are of the 6.5' version, the last 2 are of the 6'.
If you have a tonneau cover, you have to remove that before setting up the tent. Easy enough, but you have to have to put it on the ground and it's pretty heavy for one person to move. I went this route because it was cheap and easy for a few overnight trips. It sets up in under 3 minutes. This pic is of me in Moab with the 6' version. FYI, the Rightline doesn't have a floor, so you can keep everything in your bed and set up the tent quickly, especially in the rain.
I think this is a cool option. I just recently learned about the over-bed-only version without a tent floor and am considering it. Especially with your photos. You mentioned different size tents; do you have the 5ft or 6ft bed version of your truck?
In-bed!
@itsthex, My Taco is a AC with a 6'+ bed. The other nice feature is this tent requires you to have the tailgate down, since it slips over the end of the tailgate. That gives you a lot of room to lay down even in a short bed. I found the 6' version too tight so opted for the slightly larger 6.5' version. I can make it work. REI has them on sale now and returns are easy peasy if you don't like it. I really like that it doesn't have a floor to mess with. I use a nemo air mattress and MMA mats for the flooring. I also recently changed out my tailgate insert (Hooke Road) which makes getting in and out of the tent much easier. Details in my build tread.
