Tacoma Sway Bar
NorCal3056
3G owners with improved suspensions. What’s the thought on removing and or disconnecting the sway bar for off road trips? Any quick disconnect kits or setups you guys are using?
I ran without one for a while. I think it depends on if you'll be doing enough moderate to difficult wheeling to justify it. If you aren't, there's probably no point. And then you'll be stuck with body lean and bad handling for no payoff. High speeds on the highway when the road has a sharpish curve will probably have you go from 70+ down to 55+ to stay in your lane, lol.
