Tacoma Roof Rack
Victory4x4
victory4x4.com
Now available!
This roof rack system allows for mounting almost anything, freeing up valuable bed space for other trip essentials. Comes coated with a 2 stage satin textured black powder coat over durable zinc primer finish.
  • CNC cut and formed from 3/16" aluminum (steel mounting brackets) with extruded aluminum rails
  • Easy bolt together installation
  • No drilling required
  • Available with or without 40" lightbar cutout
  • Milled T-nut access points
  • Powder-coated
  • Hardware Included
  • Made in the USA
  • Free shipping!
Use coupon code "Tacoma3g" to save 5%!
https://www.victory4x4.com/product/VT23RK.html
Install Video:
I dig it! I’ve been back and forth on what rack to get but when the time comes I think I will go with this one to support you guys. Not sure when that will be yet, but eventually for sure.
Now available!
  • Powder-coated
  • Hardware Included
  • Made in the USA
  • Free shipping!
What Light bar goes with this? Is this one purchased by you Victory 4x4 or is this one I'd have to get elsewhere?
i just installed your roof rack and the wind noise is verry loud any sugestions on a fix?
Are the front and rear fairings tight against the roof with the weather stripping installed where they contact? I haven't heard of a rack being that loud under any conditions, so if they are tight and it's still howling I'll need you to reach out directly to our tech support team here so they can help you. [email protected] or 269-459-8447
Wind noise I can deal with as I'm sure it'll be there anyway with the Four Wheel Camper that I'm also gonna have on the truck. I want to have the roof rack because while I know I won't be able to use 60% of it, having at least one Pelican case at the front will make for some handy storage of dirty recovery items and such that I don't want inside the cleaner areas of the truck.
(Not my truck in the photo.)
