Tacoma Leaf Springs 2005-2023 MD HD XD Archive Garage
ARCHIVE
*T3G members start conversation for 5% discount
Archive Tacoma leaf packs are designed by Archive for severe duty off road travel!
-Made in USA with 5160 US steel, tip insert pads, FULL military wrap (only brand with wrap in HD/XD range), bolted spring clips
-Top quality POLY bushings are included in price.
-Archive springs were tested for 2 years on dozens of Tacomas
-Carefully designed to NOT have interference issues so common with aftermarket springs in the Tacoma market
-Intended Weights (added to rear axle):
LD: 0-300 lbs (reduced payload)
MD: 200-700 lbs
HD: 600-1250lbs
XD: 1250-1750 lbs
MaxD: 1750-2500 lbs
-Archive LD & MD springs deliver 14" travel with Archive Hammer Hangers and shock relocation.
-Archive HD, XD, MaxD springs deliver 12" travel with Archive Hammer Hangers and shock relocation.
ValleyTaco
with our full Archive setup: MD springs, Hammer Hangers, 3.6" shackles, our 2.5" Relocation, U-bolt flip Option 3, and 2.5" x 14" King Short body shocks.
SeekoutBeauty/TinyRigCo with our full Archive setup: HD/XD springs, Hammer Hangers, 3.6" shackles, our 2.5" Relocation, Archive U-bolt flip Option 5, and 2.5" x 12" Kings.
Source: https://www.youtube.com/watch?v=vjt1Ovqau3Y
Here's our XD pack. It has an extra leaf, 6 over 1 and rated 1,250 to 1,750 lbs added to rear axle weight. Weight adds up really quick!
I have a 2019 sport access cab, 6’ bed.
150 lbs for sliders
47 lbs for engine skid
45 lbs for trans skid
123 lbs for Diamondback tonneau cover
30 lbs for bed mat
Recently we upgraded our camper, it’s 3,900 lbs and a 575 lb tongue weight and use a weight distribution hitch that works good. I just have to watch how much gear I bring.
I’m thinking the best option to improve towing with this tongue weight is a full suspension upgrade.
Looking at your HD springs and then either add the Bilstein 6112 in the front and 5160 in the rear. Also looking at the OME 4004 coil with MT64901007 front and MT64601014 rear.
What’s your opinion on this proposed setup?
150 lbs for sliders
30 lbs for bed mat
Note that ACs are a bit lighter on rear axle.
So our HD springs are intended for a minimum of 600lbs added to rear axle. Otherwise, the rear lift will exceed 3", such as in your case when you are not towing.
Of the weight you mentioned, your rear axle/leaf springs would see about:
75 lbs for sliders
25 lbs for trans skid
140 lbs for Diamondback tonneau cover
30 lbs for bed mat
About 370lbs on rear axle.
But I'd subtract about 150lbs for AC to use our ratings.
575lbs tongue load is ~750lbs on axle
Our Add-a-leaf for stock springs would deal with your situation well, or consider our MD springs.
But I highly recommend you also add the Hammer Hangers base kit since you're towing quite a bit, and the HH really help ride, control and composure, which gives you confidence while towing, instead of white knuckles
Thank you for the quick response and info. I need to take some time to figure out what components to go with.
I was afraid of the recommendation of the HH, I seen the install videos, lol.
I will be installing everything, and can do the HH, but it will be a pain in the ass.
How much lift do you think the MD springs would give when not towing ?
Our website has lift per weight info under
'Product fitment notes' down the page
But probably 2.5" normal load
When I lifted my '16 I changed the 1/2 inch u bolts to 5/8, just had to open the shock plate holes a little to get them to slide through.
Installed the Archive Garage HH with cross bar, Archive add-a-leaf and Bilstein 5160s last weekend. Removing the 8 rivets was the longest/hardest part, everything else was easy.
I’ll finish the front Bilstein 6112s this weekend and the test run with my camper in about 4 weeks. I got about 1.5-1.75” lift in the rear.
Hammer hangers are on my list for one of my next modifications. I am just planning on the hammer hangers without the cross bar.
How long did it take you to do the job? Any tips for dealing with the rivets?
It took me about 10 hours with the add a leaf and shocks. The rivets took most the time. Just grind and drill like all the others I watched on YouTube for tips. I did cut the hanger off close to the frame to be able to drill straight on at the lower rivets. I bought some cobalt drill bits to help get through them.
