I am aware of Taco lean and it's in the front left. I don't see many people talk about the rear. I've noticed it was present for a while now. Any input?
Some say just slip a shim/spacer in the rear left.
This is with a 1/4 tank of gas. I do have the bed stiffeners. Could it be the bed stiffeners causing it or making it appear worse? Was I supposed to relieve all the pressure off the rear before tightening the bed stiffeners? Could it be that the axle rotated when doing the lift? Loosen both sides and then retighten the U-Bolts? When doing a search I saw some had experienced the same lean in the rear.
Ran across this on this forum. First time hearing it's more the rear. I always thought the taco lean was the driver side front.
I guess the rear left is just lower no matter what.
edit because I explained it opposite of the norm. I think I got twisted thinking about the way your suspension is currently sitting, higher on the driver, which is not the norm. The normal "taco lean" is the drivers side (especially the rear) sitting lower than the passenger.
