Switch pro install
Taco_primo
EDIT!!!!!
Read a few posts down.
Ok, well here it goes. It’s not complete......I am going to do some under hood clean up soon, this is it for now though.
First off, due to me having crawl control, the SDHQ Mount needed a bit of modification. The highlighted area needed to be removed
I used a file to do some metal cleanup after.
Here you can see the right clearance after trimming.
Here it is mounted.
Next I prepped the dash
start by removing the kick panel on the left by removing this plastic nut with your fingers, then pop off the first door sill and the kick panel.
That will expose the 3 screws you will need to remove 10mm socket works great.
gently pop this lower panel out after removing the 3 screws.
Now this part will only apply if you are doing the SDHQ dash mount.
Screw in the 4 threaded studs supplied with the Switch-Pros mounting hardware and then put on the small plastic plate.
Next you will install the larger clear backing plate and install the 4 provided screws
Ok so next I routed the blue ignition wire into the cab through the firewall in the harness grommet.
You’ll have to cut a slit in the grommet.
This is on the drivers side next to the brake master.
I just got a metal coat hangar and straightened it out. From inside the cab, push the hangar through the hole you created and tape the wire to the end, after it’s nice and taped on, you will pull the hangar back into the cab and the wire should follow. You will have to do this with the switch harness as well, that’s how controller will hook up. I also took some of the braided look and heat shrink and covered the wire for protection.
Now for an ignition source, I just got out my multimeter and started poking on plugs of the same gauge wire until I found one.
Under the kick panel on the left you will see this plug and there is a lime green wire, I just cut back some of the shielding and tapped into this wire.
Next I had to hook up the white wire to a light source, I chose to tap into my head lights, this way when my headlights are on the panel will dim.
It’s the red wire on your low beam plug.
Now i hooked everything up and made sure I got power to the panel and it was on and functional.
Now that you have everything installed and functional, it’s time to wire your accessories. I am running a rough country 30” light bar, Baja designs squadron pro fogs for ditch lights and a ARB dual compressor.
Now it’s actually really easy. For my light bar, I cut out the relay harness and got it down to just the 2 wires. Switch 1 is a brown wire, you connect the brown to the power wire from the light bar(i soldered it) you can use butt connectors if you want. You will have to crimp on a eyelet connector to the ground wire and then just ground to a body ground.
Feel free to ask questions and I’ll do my best to answer.
Oh and this is the mess that I still have to clean up
Just waiting on a busbar and distribution block to clean it all up.
Damn Good write up. I didn’t think of trimming the mount when I installed mine because of the harness on the fender. Good idea. But I wired mine differently. I hooked the blue ignition wire to the ac fuse, and the white wire to the high beam fuse. That because I’m using the white wire as a trigger for the light bar to turn on with the light bar and the pink trigger wire for the reverse pods on the back.
Yeah I had already had that under dash wire tapped for the ARB compressor, so I just went ahead and used it again lol
Ok so I hate sloppy installs......so I can’t leave well enough alone. Started making my template and just waiting on my sheet of aluminum. Let the cutting and bending commence.....hopefully soon.
Here it is mounted.
This is a silly question it with this setup you no longer need relays and fuses?
Got my power tray purchased. There on back order for several weeks though. Plan is to install it like solscooter with bus bar etc so its nice and clean. Will post final pics up. Those trays are frickin expensive. 100+$$
Yeah, they are expensive! That’s why I made my own lol. Just used a jigsaw, a vise and some files.
$13 is all it cost me to make it. Amazon just ordered 1/8” aluminum in a 12x12 sheet.
Not a sexy as a power tray, but she works.
Great write up. I need to have documented my past few installs a little better but I've done 2 in the past few weeks, each getting better than the last and am gonna do a refresh for another buddy with some ideas I have. I'll be sure to document the process but heres a finished pic of the latest one. I've been making custom harnesses for all accessories, using TechFlex, weatherproof heat shrink and weatherpack connectors. Makes for a clean factory looking install
Looks good! Well done. It’s not always easy doing a write up. I had planned on doing a detailed write up on the install of my CBI hidden winch bumper......then I was on a time crunch and I didn’t take any pictures.
I hear that. This particular install was part of a 2 day thrash to do a pretty in depth build for a buddy and while we had fun and sorta took our time, we didnt take a ton of pics. But over the course of about 10 working hours, we did front and rear suspension (fox 2.5's, camburg uppers and deaver u402 leafs) switchpro 9100 on sdhq mounts, ditch and chase lights on sdhq mounts (baha designs squadron pro and sport), 30" OnyX6 hi-power on sdhq behind grill mount, sdhq sliders, prinsu rack and an alignment
MONEY!!!!! That’s awesome :love:
Lol. Many of the parts were swapped from a previous truck but definitely some money spent! These trucks can certainly be that way, ask me how I know!
Oh yeah, I know. I have an issue with not buying cheap stuff :cautious: I normally go by the motto by once, cry once. I wish I would have gone with the BP-51’s but live and learn. Guess I just have to spend more.
