Spark plugs
Jemmert
Anyone doing this yet? If so where did you get your plugs and what type and part #? Dealer said motor won’t like anything but oem
V6 DENSO FK20HBR8 I believe is what they use can buy it anywhere
Iridium tipped only
.031gap
EVERYTHING on your car won't like anything else but OEM:sneaky: they will say that about everything , you motor will ONLY like toyota certified generic oil from a drum:D...
Found the denso plugs on rockauto for 12 each and they had them here the next day. Did not have to take intake off and took all of 45 minutes for complete job. Denso 3491 is the exact same plug as oem. Definitely remember to disconnect the negative terminal.
Any work disconnect negative first then positive
If the car loses battery power for a extended time then yes it forgets its "settings" if you will
If you disconnect the negative terminal, there is no need to disconnect the positive terminal, unless you are removing the battery.
That's true regardless disconnect negative when doing engine work or electrical or even take the cover you terminals or take the battery out so tools dont drop and connect
I wasn’t looking forward to taking off an intake. What did you end to take off?
If I recall correctly, the 3.5 V6 in my 2018 Tacoma comes with 3 Denso and 3 NGK plugs. Does anyone know the part number of the NGK spark plugs?
Thanks.
