Ruido culata derecha y pistoneo
JOSE VERDUGO
Que tal, tengo una tacoma 2019 y tengo 2 situaciones molestas.
La primera es que cuando le pido fuerza al motor se logro escuchar un pistoneo o cascabeleo, a veces fuerte, a veces debil.
EL segundo es un sonido en la culata derecha, me dice toyota que es un ruido normal de la bomba de gasolina de alta presion, pero es demaciado fuerte , alguien ha experimentado algo similar y encontró el problema ?
You're the first Spanish speaking guy here, so we might have a little difficulty with that. However, google translate helps a bunch.
Translation:
What's up? I have a 2019 tacoma and I have 2 annoying situations.
The first is that when I ask the engine for power, I can hear a piston or rattle, sometimes loud, sometimes weak.
The second is a sound in the right cylinder head, Toyota tells me that it is a normal noise from the high pressure fuel pump, but it is too loud, has someone experienced something similar and found the problem?
I haven't had that particular problem, but I've heard a few other guys that have. Let's see what the rest of the crew says.
