Relentless Fabrication - 2016+ Tacoma Front Bumpers!
Relentless Fabrication Bumpers offer far greater approach angles, wheel well clearance and overall strength compared to factory components all while giving an aggressive clean look. Every bumper includes standard winch mounting area and solid recovery points and includes necessary grade-8 hardware and mounting brace plates to increase the strength of factory mounting plates.
- Steel bumpers are made entirely from 3/16" steel with solid 3/4" thick recovery points.
- Standard winch mounting plate for winches up to 10k
- Frame bracing plates for heavy recovery and winching
- Requires cutting factory bumper cover and fender flares
- NO MODIFICATIONS to the grill needed
- Standard square fog light cutouts for Rigid Industries D-Series or Baja Designs Squadron Sports
- Approximate weight starts at 135lbs and can vary depending on hoop options
We offer 3 different models (Stealth, Summit, Predator) for 2016+ Tacoma
STEALTH
SUMMIT
PREDATOR
**Each bumper is hand built to-order in our NV fab shop: Lead times apply. Current lead time is 14-16 weeks**
STEALTH
SUMMIT
PREDATOR
