Ray10 sizing help?
gene158
I’m gonna pull the trigger on some ray10s when scs gets their next shipment in. I was originally thinking of doing 16s but now I think I’d rather go with 17s. I’m just not sure if I should do the 17x8.5 or 17x9. I have a trd sport dcsb and I plan on doing 265/70/17 tires, either ko2s or falken wildpeaks. My suspension is stock.
Which size will fit best?
I
went with 16 because the illusion that the tires are bigger, offset and width difference I couldn’t tell you the difference though of what’s the better choice, if those have the same offset probably the 8.5 with that size tire
If you're going to stay with a 265 size tire then I think you should go at max with the 8.5 wide. I currently have 265/70/17 on my 17 x 8.5 and I feel like the tread pattern is not nearly wide enough to look right on the wheel.
I
Can you post a pic?
Can you post a pic?
The thing about width is you need to determine how much sidewall you want, the wider the wheel the less sidewall protection you have. I run a 12.5" wide tire on a 7" wide wheel and it provides a bunch of sidewall that provides me more traction when aired down. Also it will help protect from all those parking lot curbs at the mall ;) lol
I’m more worried about the curbs lol. There’s not much good wheeling to be done locally so my truck spends most of its time on the pavement. Obviously I want a functional setup but I’d be lying if I said I wasn’t mainly concerned with looks. For what it’s worth, mountain biking and motocross force me to drive through some shitty dirt parking lots! ?
