christopher.campbell
✓ • Bronze
- 11
- Upvotes Recieved
- 15
- First Name
- Chris
- T3G Member
- #925
I put in 5100 on my 2017 Tacoma DCSB and then took it to get aligned and noticed a positive wheel camber. Any suggestions on how to fix this?
Are you running stock UCAs or did you upgrade them with the lift?
Did you notice the positive camber on your alignment sheet or visually on the truck? Depending on how much it is, they should have been able to dial that down to almost nothing. But if already is almost nothing, you will be fine. If you do have an adjustable UCA you’d be able to tweak it further if you really need to.
Yeah, that much wouldn’t be normal. They shouldn’t have sent you away like that, IMO. I know (depending on the lift) it can be a little tricky to get it dialed in perfectly, but it can be done.I am running stock UCA. I noticed the positive camber visibly. It’s enough i can tell it will wear the tires pretty bad if not corrected. I’m taking it in to the place I had the alignment done to see if they can correct it.
Another option is having a dealership do it. Toyota has the best info on how to align your truck as sometimes shops dont get that info as quickly, they should be able to correct the camber no problem. Also, as Tyler mentioned, i would look into some aftermarket UCA's. Not just for an alignment sense, but an offroad one as well. They will allow for better travel and reduce the risk of binding in the shock.I am running stock UCA. I noticed the positive camber visibly. It’s enough i can tell it will wear the tires pretty bad if not corrected. I’m taking it in to the place I had the alignment done to see if they can correct it.
Awesome! I’m sure that is a relieving feeling.Update: I took my car in and explained the issue and they were able to fix it!
