Anyone figured out a fix for the passenger seat shaking at or over 75mph? I don't drive that fast often and when I do it bothers me till I'm able to ignore it.
I'm at 34K and I've become used to it. I honestly don't know how to fix it.the last 3 days my passenger seat has been shaking like crazy. My truck only have 4k miles on it.
Didn't know seat jackers were a thing
Check the jack and tools that are located under the seat (if it’s a double cab)I'm glad I found this thread and it isn't just me! I have 2k on my truck and the passenger seat bouncing has been bothering me since the day I bought it. For longer trips, I wedge a coat or fold up a beanie between the seat and center console to stop the shake. Now if I can only figure out what the muted thud is coming from the right rear passenger seat every time I hit a pothole or bump in the road...
I checked once, everything seemed fine, I may shove a towel over it and see if that cures the noise.Check the jack and tools that are located under the seat (if it’s a double cab)
That's what I usually run and always vibratesI also found having at least 34psi in the tires help minimize the shaking.
Yeah. Had this issue before and after the many balancesHave you had your tires balanced lately?
Never done that. This was an issue even before I went from stock wheel/tire set up to aftermarket wheels and 33's. It's become a "characteristic" of the truck. I've come to terms with it.Have you tried rubbing your hand flat across your tires to see if there's any flat spots or humps?
If I'm getting on your nerves just say so, I just want to help you figure out what the causes are because I had the same issues and it's now completely gone.
I once took out the entire seat (there's bare metal on the frame and wanted to clean/paint plus wanted to see if there's anything loose) and still didn't help after tightening everything back up.Also have this issue since I have owned my truck. 3 sets of tires, balances etc. it has always done this. Glad I am not the only one as well. I slide my pac seat all the way back and it makes it less prominent and is also out of my line of sight at least.
I wonder if a weighted rear seat cover like a molle panel with your supplies in it would dampen it?
If this ever ends up being a simple stupid fix, I'll burn it down.And I have had this issue since I bought the truck brand new with 12 miles on it. My first seat shaking experience occurred when I got on the very first freeway with ~16 miles on the odometer.
Just wedge a beanie or small towel in between the center console and the passenger seat. Will solve the problem.If this ever ends up being a simple stupid fix, I'll burn it down.
This worked? I'll try it out.Just wedge a beanie or small towel in between the center console and the passenger seat. Will solve the problem.
