Whats up T3G. This can be the OME thread for photos, questions, etc. This suspension is an Austrialian made quality suspension meant for running the outback. It has served me excellent by creating lift as well as increased performance over stock OR suspension. It is a lower level suspension system but perfect for those wanted the looks combined with increased performance of light-medium offroading.
For this suspension I’d recommend:
1) Upper control arms of your choice. For this priced suspension most choose LR UCA’s.
2) Front struts. Firm struts for running added weight or sport struts for normal weight.
3) Driver side trim packer
4) Springs. Ive attached a chart for heights/weights
5) Rear Sport Shocks
6) A leaf pack. Possible options are HS-3 AAL or Dacker full replacement packs.
Optional needed items:
-Carrier bearing drop
-Extended brake lines
-Shims
The above lift will yield between 2.25-2.75” approximately. You can also add 1/4” or 1/2” metal spacers ontop for a full 3” lift which I have done without issues.
-Shims
