Not starting when engines hot
Avgtaco
I have a 2017 Tacoma trd sport and it just now started to have an issue that when the engine is hot it won’t fire back up if turned off it’ll crank fine as if nothing is truly wrong with battery and spark plugs I have to jump it to get it going again it is throwing 3-4 codes; being idle air control sensor and boot 1,2 are lean. Can’t think of anything wrong cleaned throttle bottle and air intake dumped a bottle of fuel injector cleaner in no luck im new to this forum but any help is greatly appreciated
Can I clarify a bit?
After warming up to usual running temperature (210-220), and turning it off, it won't immediately restart? (Yes/no?)
And it will restart at that same moment if you jump it off?
You've replaced spark plugs and boots, cleaned throttle body and air intake, as well as used a tank with fuel additive and still no change?
Yes, I have not replaced spark plugs nor the boots but have cleaned TB and the air intake put gas cleaner in and drove to drain the tank still no change correct
First two paragraphs. Yes? No?
So if it jumps off, I think you're looking at either an electrical connection issue somewhere between the starter to the battery that may be corroded, and when heated (and therefore expanding) is having problems connecting, creating more resistance and making your truck think there are sensor issues.
Or it's a bad battery. Hope that's it. I'd check the battery first.
