T3G vendor @ARCHIVE dropped some unbiased leaf spring knowledge in another post and I feel this information is valuable enough to warrant its own sticky thread.
Archive Garage designs and builds popular suspension upgrades for our Toyota Tacomas, such as their "Hammer Hangers" shackles, U-bolt flip, shock relocation towers.
The following information is something you should consider when deciding what manufacturer to go with, however, depending on how you use your truck, all of these options might have their place, and should not be completely disregarded. If you were set on a certain leaf spring due to personal preference, a good sale, etc, please feel free to ask further questions regarding the subsequent issues mentioned, either in this thread or in a new thread.
To add to the thread, I am going to gather the various load ratings and prices and add them to this post as well.
| All-Pro: low quality import that is designed with narrower than stock junk bushings(!), with low arch, really long and often goes flat on a Double Cab with minimal weight. You will often see the shackle rotated way back. Also it doesn't have a spot to bolt the parking brake cable tab to. No overload Alcan: Stupidly long design, requires Archive Hammer hangers to work properly, because with stock hangers, the leaves will rub the shackles, and has MAJOR design flaw that the 2nd leaf extends inside the shackle, which when driven offroad has caused dangerous binding, and shackle damage. No overload Icon: This has been pretty decent I would say, but I have gotten some negative feedback, mainly its just underwhelming. No major design flaws, no shackle interference. Doesn't seem to be a very tough design, or enough lift. My biggest nitpick is they took a 10 leaf pack design, took a couple leaves out, and screwed up by making the stepping from leaf to leaf too wide, which seems like some customers report a lot of axle wrap, which exhibits as driveshaft vibration on take off and deceleration. Stage 1 and 2 are total of 7 thin leaves Dobinsons: Newer but I like the design, it is affordable, and anyone considering an affordable option should investigate these. Has overload Deavers: The U402 expo series is currently the best on the market, for now. With 3 stages to choose from. Note that the stage 2 & 3 have less arch due to being heavier duty. Has overload. The price is up there. (Don't buy their J66 lame wrap-central pack) Archive: Archive Garage will be testing our own design leaf pack in the next few weeks. (Potentially available by summer) Archive set out to build a leaf spring that just plain works, high quality material, built in USA and has a full military wrap, bolted spring clips, tip inserts on all leave ends, correct bushing sleeve width. It will not have the issues like shackle scraping or jamming leaf into shackle, won't take an 'M' shape, isn't too long, issues which are so common. Dakars: Pretty lame design overall, doesn't have a full military wrap, and has MAJOR design flaw that the 2nd/3rd leaves extend inside the shackle, which when driven offroad causes awful noises, dangerous binding, and shackle damage. Numerous customers have complained, I have contacted them and explained the issue, and it seems they purposely have done nothing to avoid serious warranty burden. They were just plain lazy, took their Hilux design and tossed in the Tacoma, called it good. Has overload. Also very short spring |
| Source post: https://tacoma3g.com/threads/rear-leaf-suggestions.9460/post-47384 |
