markschmidl
Does anyone have a wiring diagram of the connector blocks on drivers side kick panel. I need it for 2020 tacoma sr. Want to add aftermarket wireless door locks.
Did you buy one already? Some of the connectors might be different on each one or connect a different way.Does anyone have a wiring diagram of the connector blocks on drivers side kick panel. I need it for 2020 tacoma sr. Want to add aftermarket wireless door locks.
I went with plug and play with remote start. I'm so glad I did. ThanksDid you buy one already? Some of the connectors might be different on each one or connect a different way.
If there's a specific one you bought, I can try and help you find the instructions for that one.
Hopefully you went the plug and play route. Worth just paying a little extra for it.
I know this isn't the connectors under that panel, but I assume the wires run up so you should be able to trace it.
Here's the factory one:
Here's an aftermarket one:
There's also the service manual.
I'm assuming you want the Main Body ECU, Certification ECU or Junction box?
I think those are the ones under that kick panel.
Great, thanks.Accessorides
