So I have the stock tires on my TRDOR. I've been having an issue where only one of my tires won't hold the proper pressure. Before it's asked, no, the tire doesn't completely deflate. What it does is drops to a few psi lower than all the rest and holds. Regardless of what I put it to. For example, I air up all my tires to 30psi - After a day and a half, three are at 30psi, and the one is at 27psi. If I air up my tires to 32psi, a day and a half later three are at 32psi, and the lame-o is at 29psi. Anybody have a similar issue, or know what in the world is causing it?
I use two different air gages to check the pressure. One of them is a standard stick and the other is a digital connected to the compressor/hose. Oh, and the third is the dash read-out.
