icon rxt alignment issue
sonofcar
got icon rxt leafs to replace my sagging stock leafs. Got everything back together, went for a test drive and and the truck is pulling to the left. Now where did I mess up? thanks in advance for any info!
area you raking in the front?? is the rear higher or lower??
Chances are it could have thrown off the front. Do you feel it pulling from the rear?
it is raked. about 1” over what the truck was stock (i think). Didn’t think it would be enough to mess up the front tho.
so jacked the truck back up, loosened the u bolts, using some ratchet straps pulled the rear end parallel with the leaf spring pivot bolt location, then retorqued. Also took a measurement from the front wheels to the the rear wheels before and after, 7/16 before under a 1/16 now and drives like it did before.
Might still get an alignment but will do it at my next service.
thanks for the help everyone.
