High ltft b2
bb1072
Had 4or 5 cylinder codes and limp mode.found broke flap in the intake.bushing is missing and not sitting on valves. Guess truck ate it. After repair it seems a lot better but still have several misfire codes. Still Very rough idle
When it does let me get above 3000rpn it evens out and sounds good.
Showing a 39% ltftb2 and goes down to 5 w acceleration
Next step suggestion.
I would like to try to help but I am having trouble following your message. You might want to take your time and reply with carefully outlined and detailed information on what happened? Some of the questions I have as I am trying to follow your post are:
What flap in the intake is broken?
What bushing is missing?
What are the misfire codes you are getting?
What did you do as a repair?
If you will give a more detailed clear explanation, I will do my best to help. No promises that I will know the answer, but I will do my best to help once I can better follow what happened to your Tacoma.
Acis in the intake manifold. Replaced with used one from a 2023.apparently there is a bushing on the inside where this acis flap is .some people have found the bushing resting on top on an intake valve. Mine was not in the intake manifold or sitting on top of any valve
Getting p301/3/5/6/0
With occasional p0174
So far replaced plugs /intake manifold /cleaned maf/cleaned cam pos sensor
Also. Really bad idle but sounds good when rpm’s are higher 2-4000 sitting in neutral until it goes into what I think is limp mode then it won’t go over 2k rpm
The additional information helps quite a bit.
A few things jump out at me:
  • P0174 (Bank 2 lean) combined with a 39% LTFT on Bank 2 indicates the ECM is adding a huge amount of fuel.
  • Since the ACIS bushing is missing, I'd be concerned it was ingested by the engine. If it bounced around in a cylinder it could have bent an intake valve, or nicked a piston.
  • The fact that it idles very rough but smooths out at higher RPM makes me wonder if you have a sealing problem (valve) or a vacuum leak that is less noticeable under load.
I'd recommend:
  1. Compression test all six cylinders.
  2. If compression is low, inspect the cylinder with a borescope.
  3. Smoke test the intake to rule out a vacuum leak around the intake manifold or any hoses.
I hope that helps.
Been looking at low mileage replacement engines bc I had that feeling. About 6k for low mileage one. I’ll report back when I test compression. Don’t have smoke machine but did spray around w carb cleaner s no luck
If the intake flap broke off and was ingested, I’d be concerned about mechanical damage before chasing the misfires too much I’d start with a compression or, even better, a leak down test on all cylinders to rule out a bent valve or piston damage.
The +39% LTFT on Bank 2 at idle suggests the engine is seeing a very lean condition on that bank. Since it drops to around 5% under acceleration, I’d be looking for a vacuum leak on Bank 2 first check the intake manifold, injector seals, PCV system, and any vacuum hoses that may have been disturbed during the repair.If compression checks out, I’d also inspect the spark plugs, coils, and injectors on the cylinders that are misfiring, and verify there aren’t any remaining pieces of the intake flap lodged in the intake ports.
What year, make, model, engine, and the specific misfire codes (P030X) are you getting? That information will help narrow it down further.
Pulled upper intake and plugs.
Tested drivers side compression and all 3 were around same at 210 but the starter quit so couldn’t compression test other side
Moved on to leak test on passenger side . Cyl 1 and 3 were good but 5 was close to complete loss. Got a flashlight and watched intake valves on c5 and turned engine with racket 2 valves In c5 and the one closest to cab is leaking the air and does not move at all w crank rotation. One closest to radiator moves normal.
I'd pull the valve cover and inspect the valvetrain. look for a broken rocker arm, broken valve spring, or another valvetrain failure that would keep that valve from opening.
If the valvetrain looks normal, then I'd suspect the missing ACIS bushing bent the valve or otherwise damaged the cylinder head. At that point the head will have to come off for inspection.
Hopefully the damage is limited to the head. If the piston or cylinder wall is also damaged, then replacing the engine is probably the most economical repair.
With what I’ve read it’s gonna be a pretty good job to replace head. Most say you have to pull engine bc oil pan and timing cover have to come off. With 175k on motor should I just bite the bullet and get low mileage used. I don’t see any reman long locks out there like jasper.
Do you think I can pull valve cover and get to that valve without pulling timing cover to remove cam?
