Gas fill up problem
TacomaLG
I insert the nozzle and can pump almost to full tank. The nozzle clicks and stops before filling up the tank completely. After that, it clicks off every 2 seconds or so. I tried every position to place the nozzle but no luck. This has happened in other gas stations as well. If anyone has any idea what could cause this, it will help me very much.
Thank you
So it is stopped before it actually says full on the gauge in the truck? That is what you are basing full off of, correct?
