drizzoh
5️⃣ Platinum
Sup 3g-ers. My name is Andrew and I have a 2021 Tacoma Off-Road 4x4 DCSB that I ordered in June '21 with no options other than tech package because I knew I would mod everything else.
I'm very into the OEM+ feel and I'm learning that I'm generally not happy with off-the-shelf anything so I've put a ton of work into modding mods and tweaking settings for my liking. That includes doing full custom paintwork for the interior trim, rebuilding a TRD Pro knob to fit with the OR color scheme, changing leaf packs a few times and having the ADS 2.5" shocks revalved twice. It's nice having a daily driver so I can put the proper amount of time into doing modifications correctly and getting this setup exactly the way I want.
I need to get better about taking pics of this thing, but here's a few:
Ze Build Specs:
Engine & Performance:
Custom KDMax Pro 10 Tune
K&N 57-9039 Intake Kit
TRD Intake Flow Accelerator
Borla High Clearance Y-Pipe
Magnaflow Overland Series SS Catback Exhaust
Powerstop Drilled & Slotted Rotors
Powerstop Z36 Extreme Brake Pads
Crown Performance Extended SS Brake Lines
RedlineTuning +7" Hood Struts
OEM TRD Radiator Cap
A/C Drain Mod
Suspension:
ADS 2.5" Extended Travel w/ Reservoirs & Clickers (Custom Tuned)
JBA HD Upper Control Arms
WarFab Tie Rod Sleeves
OEM 4Runner Lower Shock Bolts
Wheelers Superbump Bump Stops (Front)
Cab Mount Chop w/ Total Chaos Plates
Deaver J66 Leaf Packs
Toytec 1/2" Rear Axle Shims
Archive Garage Hammer Hangers
Archive Garage 3.6" Shackles
Archive Garage Stealth HD U-Bolt Flip Kit
Archive Garage Yellow Bump Stops (Rear)
ARB FK29 Carrier Bearing Spacer
Sway Bar Delete
Exterior:
Morimoto Gen2 XB LED Headlights
Diode Dynamics Elite Series Fogs
OEM TRD Pro Grille w/ OEM TSS Garnish
Heritage Grille Badge
Raayoo Front Camera
Hella Supertones Horns
OEM TRD Skid Plate
Ark Splash Guards
Squareone Creations Frame Caps
SNS Designs ABS Sensor Guards (Front)
Westcott Designs 20° TIG Welded DOM Rock Sliders
Black Painted Calipers & Rotors
MESO V5 Sequential LED Side Mirror Turn Signals
AVS Low Profile Smoked Window Deflectors
MESO 'The Gasshole' V1
Archive Garage ABS Sensor Skids (Rear)
OEM Header Bed Rail w/ End Caps
Rocky Mounts Driveshaft Track Bike Mounts
Charvonia Designs Billet Tie Downs
TMCMakes Wheel Deal's Bike Wheel Mounts
BedRug Bed Mat & OEM Bed Mat
OEM LED Bed Lighting Kit
OEM 2016-19 Driver Side Bed Storage Compartment
Total Chaos Bed Stiffeners
OEM Electronic Tailgate Lock
OEM '21 TRD Pro Tail Lights
MESO Total Tail Stage 1
TRD Heritage Tailgate Badge
EyeCatcher Tailgate Letter Inserts
Interior:
OEM LED Homelink Rearview Mirror
MESO Custom 9-Switch Left Panel
AOB Factory Style Push Switches
OEM Glass Breakage Sensor w/ Tundra Mic
Caliraisedled 6000k Interior LED Kit
VLEDS Aqua Footwell Lighting
Door Beeper Speaker Removed
Screen ProTech Film Protection Kit
Tacos4Cheap MGM Glove Box Letters
Tacos4Cheap MGM Bucket
JKCOVER Glove Box Organizer
K&N VF2005 Cabin Filter
OEM RAV4 Cubby Light
Z Precision Cup Holder
Custom MGM Full Dechrome
Custom OEM TRD 'Off-Road' Shift Knob
MESO Black TRD Push Start Button
MESO Extended Fuse Cover V2
MESO Steering Wheel Control Fix
MESO Black Door Handle Covers
Suntek CIR Window Tint
JDMCAR Rubber Center Console Inserts
JSTOTRIM Seat Bolt Covers
Tufskinz Heritage Door Sills
Black TRD Striker Covers
Husky X-Act Floor Liners
Wheels & Tires:
Volk RAYS 17x8.5 -10 TE37XT M-Spec Wheels
9SIX9 17x8.5 -10 SIX-1 [TE37 Rep Spare Wheel]
Nitto Ridge Grappler 285/70r17 C-Load Tires
WheelAdapter.com Extended Lug Studs
Muteki SR45R Lug Nuts
Hodakaguy's Spare Tire Hoist Relocation Mod
Audio:
Pioneer DMH-WC6600NEX
JL Audio VX700/5i DSP Amplifier
Focal Flax Evo PS 165 FXE Component Front Speakers
Focal Flax Evo PC 165 FE Coaxial Rear Speakers
JL Audio Stealthbox w/ JL 10TW3-D4
iDatalink Maestro RR2 Interface Module
JL Audio Water Resistant Master MAXI Fuse Block
45 sq/ft of Second Skin Damplifier Pro Deadening
36 sq/ft of Second Skin Heatwave Pro Thermal Insulation
Other Accessories:
Overland Equipped Auxiliary Power Kit
Cali Raised LED Relay Holder
Aspire Brite Box Fogster
Baja Designs 30" S8 Light Bar
Baja Designs S2 Chase Light
Fluids:
ATE TYP 200 Brake Fluid
Mobil1 0w20 w/ TRD Filter
Redline CV-2 Grease
Awaiting Install:
Performance Pedals Billet Aluminum Pedals
Future Plans:
On-Board Air Compressor
Auxiliary Lighting
Ze Build Specs:
A/C Drain Mod
Suspension:
Sway Bar Delete
Exterior:
Raayoo Front Camera
OEM TRD Skid Plate
Ark Splash Guards
Interior:
Wheels & Tires:
Audio:
Other Accessories:
Fluids:
Redline CV-2 Grease
Awaiting Install:
Future Plans:
Auxiliary Lighting
