Dakar AAL Heavy duty Constant Load?
TheMrThumper
Hello,
I am building my 2019 OR DCSB to serve as a daily driver work truck and weekend offroader.
The goal is to add Active cargo system rack and body armor.
I plan on loading this truck up from time to time either for work or for Overlanding with a RTT
I am considering a Fox Level 3 kit with Dakar AAL for Heavy Duty. It is specifying that the heavy duty is for Constant load of 660.
Can anyone clarify why its specifying Constant Load. I want to make sure that my truck can handle a heavy load but I am not certain if it will be constantly loaded.
Thanks in advance!
Hello,
Thanks in advance!
If you dont have a substantial load on it full time , it will be to stiff and will possible cause damage to other suspension components as it will not flex when needed to another option for you scenario would be a decent leaf setup and bag, air up when you super heavy on load etc.
I'd set you leafs for armour, rack etc what ever will be on full time . Then use a bag system to make up for the rest
