You gonna cut the bumper so the full tire is exposed? Half the tire? 1/3rd? lol
be sure to add a light or at least a reflector to outsides to maintain legality.Light buckets are made. Recessed to avoid damage while on the trail. Working on wiring now. I’ll have all the details of the wiring of the rear lights just for anyone who needs it in the future.
Maybe I’ll be able to drive this turd and take mall crawl photos later
just one of those dumb things ive been stopped for before. Doesnt seem like a big deal, but any reason to avoid attention is a good one.Man you get me every time lol... I didn’t even think about that until now. I’ll grab one of those small trailer amber lights to mount on the side.
Good looking out![]()
Its
just one of those dumb things ive been stopped for before. Doesnt seem like a big deal, but any reason to avoid attention is a good one.![]()
That will look interesting.Now I’ll get to working on the short headache rack, tailgate and now that I can see my leafs, I need new leafs. Also, I’ll eventually finish the top with diamond plate, just need to drive back out to the metal supplier....
Gonna draw up a crossbar/ tire carrier that will lay across the top and flip up to move the tire out of the way.
This is useful. I should put it in its own thread as a tutorial/resource.Here’s the wiring for the rear tail lights on the 3rd gens. Could be useful for some if your going with a cap with new 3rd brake light and if you wanna add some pod lights for reverse, etc.
The ground/ neutral is a ground. I was writing while I did this on my own lol. Running back and forth to hit the brakes, flashers, running lights and writing it all down
the bed is turning out soo good
no issues except turn signal is too quick. Hazard is slow like normal though.
You've got hyperflash, when I replaced all my bulbs with LED's I had the same issue. I ended up putting resistors at each rear turn signal since there was more room back there and much easier to access. I can't remember who made them or where I got them but they are quality resistors, waterproof with heat sinks. I'll see if I can find the receipt and report back. Also, the reason they flash normal as hazards is it uses a separate flasher/relay which bypasses the the turn signal "bulb out" circuit which intentionally flashes fast to indicate a blown bulb. This circuit uses the stock bulbs resistance to "slow" the flash rate. There's precious little resistance in an LED, hence hyperflash....
The flatbed on the tow rig does the quick flash. Ive been too lazy to address it, but I need to move the bed to do fuel pump, so may be the time for me to address that as well.oh yeah for sure. Warfab mentioned it early on and I wasn’t sure if it would mess it up or not, but it did. I ordered them yesterday just waiting on them to come in!
I did get some that were waterproof and with a heat sink so hopefully they will hold up
First video is up. This is pt1 as there will be at least 1 more.
Original link: https://www.youtube.com/watch?v=gDvWJIrz0K0
Great job on the video!! Seriously man, you're giving me bad ideas. HAHA
That looks fitting, nice job.Finally made a tailgate. It’s not perfect but it holds the stuff in the bed and that was much needed for our trip to the lake.
It will hold the license plate and back up camera, also recessed like the lights.
While I’m at it I’ll get the crossbar that goes under the window done after vacay. Checking things off the list, slowly but surely.
