Boykin's Bodacious Budget Build
howlingboykin
Starting a new thread to track my progress on my 2020 Tacoma SR. This is my first Tacoma and I really didn't know what I was getting into when I bought it a year ago. This definitely won't be my last, but is what I have for now. She's a looker though! I've never really been one for doing things on a budget but gosh 4x4 is expensive. I'd love the V6 but the I4 is treating me well for now. I don't do much technical driving so 4x2 suits me just fine. Anyway, here's my build and progress. I've done a lot of minor changes but am now starting to ramp things up. I hope you enjoy!
Fresh from the dealership:
How it looks now:
The very first thing I did was trash the air dam, as I'm sure everyone else did too.
Interior
Rago Fabrication Console Molle Panels
Midland GMRS Radio
Exterior
TRD Pro-style Grill
Tacoma Side Emblems
Matte Black Tacoma Wheel Well Fenders
Midland Low-Profile GMRS Antennae
Cali Raised LED Fog Lights
Rough Country 2" Level Kit
Suspension
Bilstein 5100 Shocks - En route
Eibach Rear Lift Block - En route
Wheels and Tires
Vison Manx 2 Overland 16x8 +0mm
BFGoodrich TA KO2 285/75/16
I haven't heard any rubbing so far in the back but the front rubs at full turn, especially when I'm going uphill.
If the 2" lift blocks didn't help, the 5100s won't either. You're still going to rub at full turn unless you raise it to 3". Even then, when you hit any bumps at full turn it's going to rub due to compression.
General rule of thumb is: If it rubs at stock height, it's gonna rub with a lift. A bump is still a bump and it's going to compress through the same range of motion no matter how high you lift it. :(
Good to know, thanks for that. Anyway, the new suspension isn't just for the rubbing. Its mostly for a smoother ride and a taller truck :D
Sweet action! At least when you go 3” lift you don’t have to worry about the needle bearings in the front diff! Tbh that’s my biggest fear when go to lift. Looks like a great start!
Update: Bilsteins came in! I've switched from the Eibach 1" block to a ReadyLift 2" block. I knew I wanted a higher lift but wasn't aware that 2" was achievable with the 5100s. Bilstein claims that a 2" rear block lift works fine with the 5100s so I jumped on the 2" block fast. Should be here this week, then I'll get the suspension on Sunday afternoon. I'm looking forward to a good 5+ hours of work 🤓
