Need some help/advice. I Installed a brand new set of Bilstein 5100/OME 887, with Icon UCA's about 15,000 miles ago. I have 285/70/17 Toyo MT tires, and I'm rubbing big time on the inside plastic. I had the same setup on my previous Tacoma, minus the UCA's and with BFG K02 (same size and wheel offset), and never had issues with rubbing, and it was never this low in the front. I'm on the lowest setting on my 5100s, and was curious if it's possible to raise the front end up by adjusting the shock setting? I called a local offroad place here, and they said not do it since it would add too much stress to the shock and it could blow it. Would a 1" spacer do the same thing? Any advice on what to do?
