Billstein/ReadyLift 3" 6112s - thoughts?
Install complete. I did end up installing the sway bar brackets. I left out the diff drop.
Front sits higher than the rear by almost two inches. Hoping it settles a little bit since they are fresh.
Maybe grab a carrier bearing drop. Since they are cheap and easy to install. Just from the little height I think it helps line things up. Diff Drop usually does more harm than good.
