BDS 4" Full Kit
MacNobody
I'm considering this kit with Fox front and rear shocks. The rear lift is provided by blocks instead of a new leaf pack. What are the thoughts on this? I don't have experience with it.
My next concern is the height of the radar in the grille. Is it possible to recalibrate this? Do I need to look at the Pro style of grille or is that a "looks only" thing included in the TRD lift kit the dealer tried to sell me?
You're better off with the 6" CO kit. This lifts the truck with the shock and coil.
Not a fan of blocks/spacers unless you really have to. IE, Taco Lean.
These are basically blocks. You'd just be throwing the truck on stilts. This is just an expensive way of doing it. More adjustments would be involved to correct driveline angles. 4" kit only replaces the rear shock. Main focus should be the front. This looks to just run off the factory suspension.
Basically a really expensive spacer kit.
