Who did you use for your alignment?4
High caster UCA and someone who knows how to align
Thanks man that's what I was looking for. I didn't know if there was some other trick to it or if it was mostly uca dependent. How ever icon does say that you should be able to get above 3° with their uca ?Honestly unless you have a UCA specifically designed for adjustability of extremely high caster you're already pretty much maxed out. Most brands including icon build in a certain amount of increased caster to adjust for lift height. What you're seeing on your suspension alignment is pretty much the max you're going to get out of anything that isn't even more adjustable. You would need something like the SPC UCAs or JBA. Both those are designed to allow increased adjustability over what standard aftermarket UCAs already have designed into them.
Thanks man that's what I was looking for. I didn't know if there was some other trick to it or if it was mostly uca dependent. How ever icon does say that you should be able to get above 3° with their uca ?![]()
Gotcha. You know anyone who wants to buy some icon UCAs?Pretty much all of the aftermarket UCAs that don't have the extreme adjustability of the SPC and the JBA UCAs have state that they can get three degrees. The big thing to consider is that's at a factory ride height truck. As the truck is lifted its ability to get that high of a caster decreases. Which is why you end up with like 2.1 to 2.3.
Post them for sale on here. They are a popular item that usually go fast.Gotcha. You know anyone who wants to buy some icon UCAs?![]()
I've be taking it to the truck shop in miramar for alignments. You have and other recommendations in san diego?Post them for sale on here. They are a popular item that usually go fast.
Tip: Most alignment shops are afraid to adjust the SPC UCAs during and alignment. You'll need to find an off-road shop competent enough to mess with them. Most alignment shops are only willing to go off of what the paper and machine say.
You can try your shop, maybe call and ask them about this. Tell them exactly what the situation is. I had a guy in San Diego that was willing to work with my UCAs (I have the SPCs), but he was never able to get a good alignment on the truck.I've be taking it to the truck shop in miramar for alignments. You have and other recommendations in san diego?
I'll look around. Truck shop specializes in Toyota's and have been around since the 80s I figured they would be on of the best in SD. But I may be wrong about that.You can try your shop, maybe call and ask them about this. Tell them exactly what the situation is. I had a guy in San Diego that was willing to work with my UCAs (I have the SPCs), but he was never able to get a good alignment on the truck.
I don't have any recommendations other than to Google around for actual 4x4 shops. I had my regear done at Brother's 4x4, but I'm not sure if they do alignments or not. I know there are plenty of 4x4 shops in SoCal, I just can't remember what they are because I moved back to NY.
Me too. Drives me nuts. I’m gonna get it dialed in by @john@mainlineoverland guy in March though. He is specifically a SPC UCA guru, so it should be good after that.firestone refused me lol, my alignment has been off forever and then I hit a massive hole offroading so my steering wheel isnt straight and passenger tire is way outta wack, I'll get to it eventually
RPM Offroad in Monrovia!I’m located in Orange County CA City of Orange where can I find a good alignment shop?
